Pc is good where your at. I would build a ported 4 mill way way way ......way befor upgrading from PC pipes. After the bigger ported motor you with still be fine with pc. Then get the shearers and a pair of air strikers 35mm.
Carb sync is a big deal on banshees. Researching and trial and error will help you. Banshees are very hands on. Can you post a video? Can you tell us about the jets that where changed when the toomies where installed. If you stick with us you will be a banshee master.
We need to know all mods done post pics if your not sure what is what.
Also what is your elevation. Did your plugs look rich? Can you do a plug chop test to see if your banshee is running good? Oily crap coming from pipes is semi normal. If you have the pipes off clean the oring and surfaces maybe replace oring and use hi temp rtv and that is all you can do. Congrats on owning the funiest quad ever.
So the resi is relocated. Not enough meat to thread. Would have left it off but it has a home. Cut top mount off and counter clock wise 1/4 turn. Then switched resi to horizontal.
Keep your banshee all original or upgrade it and avoid crashing or rolling it? Those shocks haven't changed since the first banshee and they designed it back In 1985 or so.
Pancake bearing , pro mod tranny, shift star, if your going to shearers or similar then you will want a pair of air striker 35mm at some point. Billet impeller , dual pingle
If you go 4 mill then you will get the 4 mill pistons and I would just go to what ever size your jugs need. Big Bore is what ever displacement your aiming for youigjt like 10 mill serval.
It is going tomorrow too. Lots to see. I saw alot of stuff I can't afford some deals on paddles and stuff. really expensive food.
Watching the race carts go around was fun. Alot of venders. If you have kids they have a spray ground and a live band.
I know you don't need them camatv but thanks for the bump
5$ Plus 125 shipping! or
5$ shipping and 125$ for pipes ok!
Just trying to help out, not get rich.
I think shipping would be about 40-50$?????idknow
