Redline Racing
HQ Site Sponsor!
    4
Everything posted by Redline Racing
  1. Is swingarm gone for sure?
  2. Got a PD cool head kit used but nice. New o rings. 22 cc domes for stock cylinder. 150 shipped. Cam
  3. That squish with that psi needs better octane than pump fuel. Have you talked to Jeff?
  4. Got an 8" no link LSR aero tube
  5. This 66 mm cylinder can be bored out to 68 mm. This would require replating. From my dyno exp the power from 66-68 is not that much. Bump for a homo
  6. Liberty is the company that makes them. Best straight cuts available . Rob just had rdz engraved in his. Matt copied no one.
  7. Sandman I haven't seen you so upset since you and builder got caught naked together. I talked to Werner cool guy. He just never made connection that his old carbs could be problem and not the domes. We will have him taken care of. But thanks for the back up sandy. Lol
  8. Yes you can use your head shell and o-rings.
  9. I talked with Werner after I saw this post. I was concerned the domes I had cut were causing damage to his mtr. After goin over how he checked his squish, his kicking psi, ign timing we went to carbs. He had bought an unknown set of 33pwk carbs . To make these carbs run he had to lean his jetting way to far down. He then bought a new set of 35 pwk carbs, which run standard jetting for a 4 mm cub. The new carbs according to him run way better. So the main problem was probably his jacked up carbs. This is why I never recommend buying used carbs unless they are off a known good running bike. My point is by reading his post it makes me look like I cut bad domes. Not disclosing the fact he bought carbs that didn't work and he leaned into the mtr with jetting. A dome with .050 squish with proper squish angle with a standard width band doesn't blow o-rings at 150 psi. So people before you make a post that may be taken wrong way by many people ASK YOUR BUILDER!!!!! Tell all info....... What ALL CHANGES YOU HAVE MADE to bike in last few month. I am not knocking Werner by any means just using him as an example ( sorry Werner ) . I could go on and on but I'm not windy . Lol Sorry to vent but I see post like this on here all the time.
  10. Brad got him from mailorderjockey.com.
  11. Got it all instock call me can shoot you a package price. 1-541-367-2453 CAM
  12. Be cool if Tyler came out. But he is a dirt fag. Lol
  13. Will be there wed thru sat!!!! Right by race track.
  14. Motor is dune ported, custom domes, billet timing plate , v-3 reeds, 35pwk carbs, CPI pipes. Motor is on race gas. Tyler is correct we bored mtr .080 over.
  15. Sorry for Dyno sheet sideways. Not smart enough to rotate it. TYLER HELP.... or anyone else.
  16. I've built quite a few of them. CPI sleeves are good head doesn't always hold o rings so well. With the kit, machine work, port work..... It is not cost effective compared to a cub. They can run very well. If you do one start with perfect cylinders. There are no room for helicoils on stud holes down the road. CAM
  17. Is it a hill race or flat drags? Lights or just outlaw style?
  18. I don't run very many PVL ignitions. But when I do I run diodes and one kill switch. I just go to RadioShack and buy some. Sorry I dont remember what size.
  19. 25 bux shipped got them instock.
  20. I'd do rear first. Front tires are barely on the ground usually. Ran them in alot of yz250f Mtrs. Worth 1hp over stock.
  21. We will be there Saturday and Sunday. Hope weather is a repeat.
  22. If you know who is building it I'd ask him. Dan is super easy to get ahold of to bounce questions off of. JMO do a 10 mm cub ..... When your bored with that than do a DM.
  23. If you are in 5th gear cruising and come to a large incline you can down shift to climb the incline no problem. You can down shift to keep bike in correct power range for your riding application. Just don't be going topped out than start shifting down to slow down. Dunables are better for back load than standard trannies. But they are not stock.
  24. I use to run it but clean up is horrible. It sticks to everything , completely trashes a good solvent tank. Works well but pain to clean. I used the blue one.
