Josh Z
Everything posted by Josh Z
  1. Josh Z
    reeds
    here you go... http://joshbansheeparts.com/ or I have a set of stockers for $20 shipped....
  2. Josh Z
    Stock cases
    Got a set about 20 min after I posted this ad. Thanks tho!
  3. Josh Z
    Stock cases
    No chain whack or other issues. No port matching etc. stock stock. Pics required.
  4. No springs in the picture... Probably not a duneable.
  5. here is a link.... http://joshbansheeparts.com/ pm with questions I'll answer them fast.
  6. our ACE doesnt have anything worthwhile. I looked for ya gary. sorry man!
  7. Check it all out!!! to the top!
  8. Josh Z
    DM cases
    I would be OK with some trenched for a 10 but a 12+ requires too much weld/epoxy thanks and still looking.
  9. Josh Z
    DM cases
    Looking for a good set of running DM cases... no leaks etc... let me know what you have and a price.
  10. Wildcard any day and Everyday! He makes sure each engine he works on is what the customer wants. He does an awesome job and bends over backwards to help you out.... AND his prices and customer support are pretty much unbeatable. Tell him I sent ya! lol
  11. sorry got it fixed!
  12. says the guy that is "Burnt Out"
  13. hahahaha SB you jackass...
  14. I have a 4 mil DM 554 cc set up I would be willing to sell or trade for (the right) 10 cub. Here is what I will trade with the 4dm Cylinder Cases (set up by wheelman chassis) Brand new UPP intakes Small DM exhaust Flanges Head & Domes Pistons 4 mil hot rods trued and welded crank w/ new Max on stator and TZ on PTO side Shearer DM inframe pipes with center mount silncers Vforce 3 reeds and cages Brand new base gasket and head orings ready to go so all you will need is a tranny, clutch set up, all the small things (I have most that I could throw in for a few bucks) and a flywheel/stator etc. I would trade this for a 10 mil cub set up must have the folowing newish plating, pistons,coolhead,domes, cylinders (must be unported or ported by a reputable builder for Shearer small bore pipes) Shearer Small Bore (prefer inframes) Crank newer hotrods, twister or M&M with TZ and Maxload (no vitos) intakes for 39 PWKs cases (treanched for the crank) no chain whack No junk please. Like I said above I wont trade this for any set up it must be the RIGHT set up for what I am doing. if you do not have all the parts listed above let me know we could work out some money to compensate the missing parts etc. here are some pics of the motor pipes etc.
  15. water in there... change it. run it for a min, then flush it like 2-3 times... if it is still milky you have a leak
  16. I want the WHOLE BIKE paul. that is the first drag bike I loved! great looking set up and I hear it runs well too... If I had the money when it was for sale a year or 2 ago it would have been mine!!! good luck on the pipes!
  17. replied thanks for your business!
  18. thanks man. just a little HTML and a little practice. will be easy to do shipping etc now too and to make changes. Buy it up!!!!
  19. Click the buy it now button next to these parts. I will ship out usually the next weekday but i will contact you if It will be later. And I will send tracking with EVERYTHING. If you want a FS add made like this for your stuff contact me... I will do it pretty cheap. Link to Parts for sale
  20. Josh Z
    cut domes
    Get in touch with a builder. a custom set of domes is usually about $80 and they are worth every penny.
  21. it really depends on your riding style etc. I HATE mikunis because you have to use a screw driver to take the slide out and again to make needle adjustments. I love the PWKs. Depending on your porting and riding style you CAN go bigger. the bigger you go the less bottom end you will have. I would stay below a 33 or 35 with stock cyls. even with some heavy port work.
  22. stick to a cp cylinder... biggest bang for your buck. call a site sponsor and discuss your options.
  23. X2 the trex is a tricky engine. and it is damn near impossible to find pistons for them nowadays. and are you positive it is the 115 rod? the 10 mil I had was a 120 rod. measure the pin size on the existing pistons, if they are 16 mm pins then it is the 115 rod if it is 18 mm pin it is the 120 mm rod. also you can call tony Doukas he knows alot about the trex and is one of the few ppl that still has and can get parts for them. http://www.bansheedepot.com/default.asp or sell it and get a CP cylinder. Whatever you do STICK WITH ONE BUILDER.
