The cylinders and pistons are already sold. sorry
-Cheetah Cub 400cc cylinders/ wiesco pistons. That run very strong. It's barely broken in. Plus i have all the o-rings necessary to just bolt on and go= $280
for that price youd sell hundreds
i called you got no answer
but what your saying in your pm is going to go way over my budget.
im lookin2 spend like $500 depending on parts Crank , Piston , Cylinder ext
i am from hillside nj 07205
the motor has stock carbs with jet kit,
Pro Design cool head 22 domes for pump gas,
i have v- 3 reeds, i will get billet timing plat,
i dont have pipes....thinking cpi are the way 2 go.. with some porting
i ride hardcore trials , full weight being 165
i have a full motor id like 2 get back together and im looking for some one to d0 the job.
supposably one bearing went bad on the crank and the piston was taping the head...
the Crank & Piston Kit. on ebay is like $500 then i need machine shop and labor.... i dont have that $$$$... i have the top end GASKETS, new cool head with new o rings 22 domz
Some one has good used parts like Crank & Piston maybe Cylinder and can put it all together will get good money for the parts because of labor and i will get a smoking deal. it worth a shot H Q...
the cheep way out is 2
get my CRANK BALANCED TRUED AND WELDED. my stock CRANK. put all new BEARINGS, Oil Seal Kit, whatever need replacing
my Cylinder are 66mm but in ok condishon . id like to get them bored 66 1/2 and pistons fitted if possible
someone can help me...... parts for a banshee and know about banshee. its banshee H Q
[email protected]
