rockenshee
Everything posted by rockenshee
  1. have you got you kill switch on RUN or is it turned OFF ???
  2. ok so the range of jets i need wil be mains 240 - 280 wil i need to go up on the pilot 27.5 been reading looks like it be best to jet it to the cold first they say go up on jet size when the temp goes up is that right?
  3. mods done fmf fattys , reeds pro series , k&n air filter in air box lid on +4 timming 64mm bore. altitude 1540 feet or 468 mtrs temp winter 15C summer 30C+ dry heat really want to re-jet my bike i did the top end really enjoying doing all the work this is the first time working on a banshee im keen to learn
  4. if you are stil on the stock 64mm bore and there are no marks in cylinders and the surface is smooth just give it a light hone and stick the piston in my bike is 06 black se did the top end 2 months ago first rebuild on this motor because all cylinders are nikasil coated on stock 64mm bore all i needed to do was hone it and install the piston and rings
  5. go the home page go to media form then to vidios top of page is CARB SYNC AT IDLE
  6. go to useful links on Banshee Repairs and Mods to download banshee service manual for free
  7. torque spec for cylinders and head are 28 nm , 20 ft pound
  8. What length exhaust springs do i need and how many do i need for fmf fatty pipes can i use the springs of the stock pipes or which brand is good to use raven?
  9. sorry that was $111.10 in postage for one air screw set to ship to australia talked to bikebandit why so mutch reply was we only work to the box size 12"x12"x12" got air screw elsware
  10. i got one thats for the offer
  11. no get you bores meassured why are they rusty to start with hone is only to get the crosshatch in clean cylinders its not a cleanning tool
  12. whent to bikebandit were gowing to charge $111.10 can someone help pls
  13. whent to bikebandit were gowing to charge $111.10 can someone help pls
  14. will order a air set screw set to replace the missing one have you heard of this before don't no how long its been gone bikes been running real good
  15. will put the stock filter back in then til i get my pipes i will get it tunned on the dyno after i put the pipes on cant see air screw on the right carby banshee is 06 special edition it was stock when i got it
  16. worked out there is only one air screw on carbys do ineed to rejet lid is on air box at the moment
  17. installed pro serie reeds do i turn in the air screw in 1/4 to 1/2 even after installing the k&n air filter is the air screw only on the left carby im new to banshees and adv the timming +4 rest of the motor is stock fmf fattys on the way
  18. its happend to me i replaced the spark plugs and that fixed it
  19. go to www.rockymountianatvmc whey have a vidio on how to do a bottom end rebuilt or put all the pieces together to see if it is all there
  20. useing a litle coolant need to top up over flow tank 1/4 after 8 hours riding is this normal is after riding it prity hard?
  21. witch paddle tyre is good for playing in the dunes needs to be tire for 180s on top of dunes and hill clibs is duro dune blaster good for that or a dif tire
  22. duro dune blaster 8 paddle 8" are they good have fattys pro series reeds
  23. porting what is the difference between woods and dune ports
  24. thanks for the info been getting parts for the us for some time because parts in oz are 2 times the price wil wait for u.s dollar to go down rockymountainatvmc been very good
