dmfisher71
Everything posted by dmfisher71
  1. like new Aimpoint PRO red dot scope bought new in February has around an hour on the batteries....very nice optic currently mounted on my AR .... have original box and manuals.... will ship to 48 states only.... asking $375 obo+ shipping..... you may message me here or for quicker response please text me at 812-390-5926
  2. ok i got a 2000 banshee motor has been completely rebuilt just got it together has less than 2 hours on top end less than 6 on crank, Hot Rods long rod crank, new wiseco pistons, fresh bore, polished exhaust ports, billet reed spacers, TDR carbon fiber reeds, milled head, adjustable timing plate (set at +4 timing), pro taper bars, new clutch perch and brake lever, new grips, new graphics, plastic has some scratches and stress marks but not to bad, aftermarket suspension (older but nice white brothers rear, unknown fronts but feel good), tires are in ok shape, i run 50/50 mix of 110 and pump fuel has FMF fatty pipes and powercore 2 silencers.... will also be including flywheel puller and carb sync tool and anything banshee related that i can find for it...i dont want to sell this but i need to....runs great i am asking $2300 obo CASH or partial trade....***PARTIAL TRADE ONLY*** trades i am looking for are guns with ammo (prefer handguns or rifles) or ????? make an offer email though here or text 812-498-4065 (text only) located in Brownstown, IN 47220 about an hour north of Louisville, KY and just a little over an hour south of Indianapolis, IN
  3. less than impressed with my banshee
    1. Dicklez
      Dicklez
      Mine gives me a boner!
  4. STUPID TORS!!!!!!!
  5. got it fixed...stupid TORS
  6. ok need to know how to test my stator and my coil.... i know i cant test the cdi... got rebuild done and know i dont have any spark.... tors has been removed as well as key switch has been removed and wires for key are tied together....the tors box (beside coil) is still there.... i need help i am already pissed with this thing ....
  7. having the EXACT same problem with mine....... but some one (before me) has cut the key switch out. do the throttle switch and tors plugs need to be tied together.....i also have tors removed
  8. thanks guys very much for the help
  9. ok put a new clutch perch on my shee, and i have no play in the lever and cant adjust it out on the perch... is there an adjuster on the basket i know there is a bolt/screw in it if that makes any adjustment please let me know what i need to do...THANKS
  10. lowered price again
  11. bump for lower price
  12. ok i have these 2 pair (at this time) of LED lights i was going to use one pair but have decided that i dont want to get into a wiring mess...these are 12v DC lights...so your banshee will need to be converted... let me say first off these are actually forklift lights but they will be very easy to use stock frame brackets i think... they are about 4 3/4" diameter and about 2 3/4" deep they hold 6 LED bulbs in them... the rear housing is a somewhat hard rubber, and they are sealed beam... one set has just a clear lense on them and the other pair look like the old style stock headlights kinda have that texture look to them... i am going to start them at $65/pair obo SHIPPED i will only ship to the lower 48 stated
  13. thats cool i just need to know how i convert it from ac to dc current.. the lights i have are 12 volt dc
  14. how do i convert it over to DC.... is there instructions to do this anywhere.... i got me a set of nice LED headlights off a forklift that are nearly identicle to the stock lights
  15. curious what voltage does the stator put out to the rectifier to run the headlights... 12 volts i assume...please correct me if i am wrong
  16. i bought the one that sprinklerman posted... is the exact same one that FAST sells..i paid like $33 shipped to my door
  17. ok got a few random parts left i just want them gone... clutch cover w/water pump $45 shipped clutch side internals with clutch set (bast has one braken ear and i think missing a couple screws)--$50 shipped kicker (little loose) $20 shipped stock reed cages with reeds and extra set of reeds (i think they might be boyesen reeds BUT I AM UNSURE) w/carb boots $50 shipped for all of them random carb parts; bodies, cable(s?), TORS tops, random internal parts... i think the bodies are drilled for TORS delete but one of messed up----$30 shipped pics http://s919.photobucket.com/albums/ad31/dmfisher71/ will only ship to the lower 48 states
  18. as of right now i have it set at +4 timing... i will check the compression when i get the top end back on... would be sooner but i ordered the wrong diameter pistons , i am the one building it...
  19. ordered the wrong damn pistons...
  20. ok i need to sell these i ordered the wrong size... but they are a brand new set of 65mm Wiseco 795 series pistons for +5 longrod crank.... come with both pistons (still in the little velvet bag), new wiseco top end gasket set, rings, pins, circlips, and needle bearings... i need to sell these so i can get the ones i need... need $265 shipped out of these will only ship to lower 48 states here is a link to pic http://s919.photobucket.com/albums/ad31/dmfisher71/?action=view&current=Pic0450.jpg
  21. ok thanks wildcard... that is where i am measuring is above the rings
  22. what i was thinking of was mixing 91-93 octane with 110 race fuel at a 50/50 ratio bring it down to around 100 octane range.... plus i REALLY like the smell of race gas..lol
  23. ok this may be a dumb question but i have never noticed this before, but i bought a set of 795 series wiseco piston on ebay... they are marked as 65mm (which is what i ordered)... but i measured them both, one reads 64.50 exact and the other is 64.49.... are they supposed to be like this.. my cylinders are on a wore out 64.5mm bore was going up to even 65mm... i have rebuilt many top ends on many different things but have never noticed this before.... or did i just get a "mis-stamped set of pistons".....
  24. dmfisher71
    stock head
    I got a good one... just needs the little water neck $$25 shipped to lowee 48
  25. i will second this, great prices EXTREMELY fast shipping bought nerf bars from him paid for friday night and got them monday from viginia (i believe) to indiana... and also he text me at 3 am to make get my correct address...great seller here
