miami350
Banned
Everything posted by miami350
  1. im looking for some Cpi Inframe pipes and also a 3 bar front bumper and a 6 pack rear rack Let me know Money in hand!!!!
  2. yup after sitting also io just put new pads
  3. yea its has the rubber diaphragm ... and also i took all the old oil out and but some new one in
  4. im having some problem with my rear brakes they would only hold up pressure for like 4 days then it get soft so i bleed them again and it does the same for 4 days What can be wrong?????.... i dont see no oil leak !!!
  5. im having some problem with my rear brakes they would only hold up pressure for like 4 days then it get soft so i bleed them again and it does the same for 4 days What can be wrong?????.... i dont see no oil leak !!!
  6. how much shipping to miami fl 33147????
  7. found out that i had the slides in the wrong carb........
  8. my banshee is popping on the right head side on top and also feel like it holding back what could it be.... there new piston in there it a stock bike
  9. I try doing it that way but the lver had to much play and the adjustment screw was was short so i put it the other way around and now i can pull the plate out
  10. well im puting in a new pancake bearing setup but dont know what side of it go in the hole where the rod and ball goes in???? and can i use the same stock Adjustment screw ?
  11. im looking for the 6 screws that hold the clutch spring in place i have 9$ In my paypal LET ME KNOW Shipped to miami,fl
  12. just got some gray plastic from a friend but they dont have no shine to them was good to use to shine them up again.... i tryed using that back to black but it dont work at all
  13. Do any one have a pic of the Pancake bearing install???
  14. still looking for some helpp me!!!
  15. how much shiping to miami?
  16. how much u want for the key IGNITION ???
  17. Title say it all Looking for Some CPI inframe Pipe Set let me know
  18. could i run #3 on a Bone stock banshee??
  19. need some frame parts: chain tensioners lower left arm "Sliver" front bumer 6 pack rack lowering kit
  20. im looking for list: adjustable timing plate good clutchs shifter lever clutch lever key switch w/key 3 bar front bumber 6 pack rear rack drive chain
  21. PM SENT ABOUT THE FRAME
  22. Im looking for a few parts for my banshee.... LET ME KNOW Need them ASAP part List that i need: Gear shifter lever Rear Axle Bearing Carrier Housing Inner Clutch Hub Frame with Title
  23. Was the link??
