miami350
Banned
Everything posted by miami350
  1. Looking a good 7 mill crank and some nice cut 7mill cases lmk what u have !
  2. im looking to buy some stock cylinders never ported and a 7mil Crank
  3. any pics of the cylinders???? ported?
  4. i could of the piston but of the inside of the cases i cant take none anymore i pour gas in it
  5. i just did a whole rebuilt on this motor new piston new main seals. so i started it rode it a few times till motor lock up and then free up againg till it started knocking so i cut it off then i took the rightside topend apart and found that on the exhaust port side a clunk of the piston broke off rings got stuck in the port. so now i see something in that side that look like some thick grease gray color what could that be?
  6. Started motor today and the same side the plug look Dry dark gray what could that be????? jets at 330 now
  7. I bought a banshee like 2 weeks ago from the auction so I was runing it on 93 for about 3min till I heard a boom so I took the topend apart and found a hole on top of right piston. So I took the whole motor apart to clean all the shaving that the piston drop so while the motor was a part I bought new main seal. And bought 2 new pistons and build it back. So now I want to know if its ok to run av gas the bike has some 20cc domes compression at 155 psi and jetting at 270 im at sea level bike dose not have timming plat..
  8. im in Fl, so id sea level
  9. Got to know if u have to run BB or SB PipeS !!!
  10. whats a good Jetting spec on a Stock crank,drag ported cylinder,35mm pwk,shearer sb inframes,1-4 5.6 override pn Av gas,, my main at 152 rite now
  11. does any one have 7mill longrod crack for sale let me know??
  12. what you mean about that??
  13. hey there havinh some problem with my 1-4m5,6 N-DOWN its hard to shift to neutral when motor is running but easy to find neutral when motor is off is the tranny goin bad?? or is it easy to fix???
  14. yup check everything..... So 100% its the clutch side seal... brokin it down in the morning
  15. plugs new, will check the oild in the morning
  16. Check the reeds...... i notice it spitting alot of unburn gas on the right side.... so it might be the seal on that side??
  17. i also swap carbs from left to right and still
  18. hey, i have a 06 Banshee im havin some problem on my right side cylinder..... the bike would idle good, but when i hit the gas that side feel like it cuts off n on i check the syn on the carb there are good. i try to swap the plug cable from the left to right and still the same also the left side exhaust Blow real hot What do all this mean??? i check compression seem fine...
  19. PRICE DROP 300OBO r TRADE For SOME INFRAMES CPI OR shearer
  20. im looking for some cpi inframe sb pipe let me know what you have !!
  21. here i have a set of left same side out frame RDZ Drag pipe for banshee in super new condition no Dent asking 380$ OBO or trade for some inframe CPI Pipe Call 786-715-4194 Mike
  22. BUMP LOWER !!!! 100 SHIPPED
  23. lmao i mean 34mm
  24. here i have some Like intake i had for my 24m carbs. also a billet steering clamp with the key bracket on it ..... Asking 115 Shiped OBO
