Banshee dav
About Banshee dav
  • Birthday 11/20/1969
Contact Methods
  • Website URL
    http://astore.amazon.com/bansheesuperstore-20
  • ICQ
    McDonough, GA
  • Interests
    Visit Banshee Super Store @http://astore.amazon.com/bansheesuperstore-20
    2000 Blue Out of frame shearer Pipes Hot Rod 4mill Crank 421 Wompus cylinders Wisco Pistons Pro Design Mega Flow Water Pump Impeller AMR stage3 rev box +10 timing plate 100 watt stator JT sprokets17/40/ RK Gold chain Vforce 3 reeds Cool Head 17cc Stroker Domes 36mm Lectrons Carbs K&N Pods with outerwear Lockup Clutch and Clear Cover 1-6 Override Trans 6" Chrome Moly Swing-arm 21x10x10 American Racer slicks Boost Bottle (Worthless)
Banshee dav's Achievements
  1. I have 2 left. They are custom made with a solid front. No grill. Paint ready. $250.00 Each + shipping. 225.00 each if you buy 2. I will except Paypal or cashers check. You can contact me @ 404 227 7510 http://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc6/208074_213794115297468_100000006432059_861255_3285452_n.jpg
  2. Find all your banshee parts here Banshee Parts Store http://astore.amazon.com/bansheesuperstore-20
  3. In frame CPI'S powder coated black. $350.00 + shipping. Contact David @ 404 227 7510
  4. I sent my trans back to Joey. He is going to repair the ramps and the dogs were rounded on third gear.
  5. No i do not have a modded shift star.
  6. I have a full 1-6 override that will jump out of gear when under a load. I changed the shift forks. And it still does it. It will shift fine if you are not putting a load on it. What could it be? it just started doing this. It looks fine. Nothing is broke or chipped. It is pissing me off bad!!!
  7. The eccentric bolt was loose!!!
  8. My bike will get hung 3rd or 4th gear if i leave hard. But if i take it easy off the line then it will shift fine.I have a full 6speed override. I can not figure what is doing it.The shift forks are fine. I don't have a modded shift star.What could be causing this. Sometimes it will get hung in 2nd or sometimes 3rd.Or it might do fine.It is not consistent.
  9. Yea i will replace them also with the new pick-up coil.
  10. The screws did not come out they just got lose. And i can see where the flywheel hit the pickup coil.
  11. It looks like my pickup coil was lose and hit the flywheel.I guess i will get a new one and see.
  12. The flywheel is fine.Could it be my CDI. It is a Stage3 AMR. I got it and a new RM stator about 2 years ago.
  13. Every thing was running fine. Then it just lost it's power. I changed plugs. That didn't help. I check compression and i have 150psi in each cylinder.Carbs are clean. It cranks fine and revs good in neutral. But when in gear it has no power. It revs clean but it sounds like it is only turning half it's rpm's.
  14. Yuo can run a 17 in the front but thats as big as you can go without cuttingIf you are still runing a stock motor then you need to stay with the 15 front and 40 in the rear.
