Sands
Everything posted by Sands
  1. Yes I have! Dual pingel fuel valve -> http://www.pingelonline.com/powerflo_banshee_race.htm And high capacity bowls for Keihin PWK39mm. Tell me one thing... My Banshee didn't run since last September where I put some lube oil inside cylinder to let them lubrified. In August I works for first time this year. Could it block the gigleurs at high rev and detonate?
  2. Ok! But a 0.012 base gast will increase more squish than a 0.020. I just saw the crank without open the engine and it seems to be fine and I have the same opinion about rod bearings. There are no small pieces from domes or pistons inside the engine and even inside de pipes. I sent a PM to M&M and I am waiting his reply.
  3. Thanks for your reply! I already pull of the cub and right now I am not sure about squish it had because the base gasket is in the trash! about thickness. It is better use 0.022" or 0.012" base gasket?
  4. It shouldn't be... I think that they couldn't sell 98 octans if the fuel doesn't have it.
  5. Those domes are 22cc cub domes and I am using Wiseco 573M06800. The carbs are Keihin PWK39 with pilot jet 55 and main jet 178-180 ( I am not sure until open it ). The base gasket has 0.012" of thickness. It has more 5 degrees timing.
  6. I already pull of the cub and there is no sign of damage on crank, but I will inspect better later. I think today I will have a time to do that.
  7. The plugs you see in the domes are new plugs. They never ran.
  8. Maybe... If you were me, what would you do? New pistons or just tore it a little on the top? About the domes, I will certainly buy a new set.
  9. On both pistons? I would believe on it if it only happend on one cylinder...
  10. OK. Tomorrow I'll do that. Thanks for the help.
  11. In Portugal we have 95 and 98 octanes.
  12. 98 octane. I didn't measure que compression after building the engine... It it happens to you, what would you do? New domes? New pistons?
  13. 421 Cheetah Cub, 22cc domes ( live at sea level ), PWK39 178 jetted, VForce 3, +5º timming, Shearer SBIF.
  14. What do you think about these pictures? Could it be detonation? The right spark plug is damaged.
  15. Where can I get one of these gasket?
  16. What thickness should I use on a 4mil Cheetah Cub 421cm3 with 22cc domes?
  17. Do you know if Chariot head domes 22cc 68.5m Blaster angle fits on Cheetah Cub 421? Pistons are 573M06800 ( Blaster pistons, I presume... ). http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230501515903&ssPageName=ADME:X:RTQ:MOTORS:1123
  18. Does anyone have new set of domes 22cc for 421 Cheetah?
  19. I have a Cheetah Cub 421cm3 ( 4mil ), Keihin PKW39 with billet bowls, PowerHead with 22cc dommes, VForce3, 5 degrees timing, Shearer SBIF. Where I live is very close to sea. The elevation is 300feet max. I use 98ron fuel. The temperature is about 25-35 degrees Celsius and atmosphere pressure is 1008mBar. What pilots and mains should I use? May I use 20cc dommes? And 6 degrees timing? Regards.
  20. Try to get the price from USPS!
  21. For long travel or oem size?
  22. Do you recommend any brand?
  23. Hi, I need to know how many links will I need to use on a Banshee with +4 inches swingarm. It uses 15-45 gear ratio. Can I use a standard one? Regards, Pedro
