Sands
Everything posted by Sands
  1. Andy, check you PM's.
  2. This is what I call a damage!
  3. I didn't rebuilt it yet, because I'm still dealing with Andy!
  4. Andy, you have PM.
  5. OK.
  6. I agree too... Andy, I sent you PM on Saturday!
  7. The clutch doesn't slip. It's hard to believe but this asphalt is very bad. I have a +2 inches swingarm.
  8. Can you show pictures of your damage?
  9. Two movies. Can you detect detonation by the sound of the engine? 15-35 gearing.
  10. First run.
  11. Sent it back!
  12. Did you get any PM from me? Sent me a PM with your email.
  13. I tried to contact him on monday using that way, but without any answer!
  14. Andy from M&M has any kind of email? I need to contact him.
  15. I think I will take the risk. I will not split the cases. I will put new pistons and domes and verify some leak on boots and check the gas cap. About timing? +4 degrees?
  16. I didn't know that. Thanks for the help.
  17. I will check that situation as soon as I can. Now I just need what domes will I use, main and pilot jet, thickness base gasket and some good luck for this engine.
  18. I don't have boost bottle, but my manifold were design for 34-36mm carb, because I bought them before start thinking of getting a Cheetah Cub. To fit PWK39, I cut the boots a little. There is something I hadn't tell you. My Banshee idle high RPM comparing to other Banshee's. Could it be a leak on the boots due to the cut I done?
  19. A friend of mine just told me that our 98 octane ( European ) is like 93 octane in USA...
  20. You are right... but I only run with Banshee for a few miles since the rebuilt... about 60 miles. Not more... And running very slow. This is the first time that I run hard for a 1/8 of mile. I think I will only put new piston and domes and choose a base gasket. If it doesn't solve the problem, maybe next year I'd try to split the cases, once again... I will call for Andy to figure out a new setup ( domes, jets, thickness of gasket ). I believe crank, bearings, etc... are in good condition ( I hope ).
  21. I sent you a PM yesterday.
  22. Both sides had the problem.
  23. Yes. There was a time that the spark plug jumps out of the engine!
  24. He just need to answer PM.
  25. 178 or 180. I didn't open it yeat. They came pre-jetted from the builder!
