forrest411
Everything posted by forrest411
  1. Thanks. Just sold it to a guy from Memphis, TN.
  2. I'm just south of Chicago. I took a deposit from a guy in Memphis a few days ago. He is supposedly coming up this Saturday to pick it up.
  3. Thanks, people debate HP all the time. HJR has a great reputation and he knew the exact setup I was running so I trust that it's in that range. Either way, this Banshee has been completely gone through top to bottom not to mention the ported 4mil stroker motor. I just sold a nice 99 Banshee with a stock motor, T6's, and some other bolt ons for $2600 so I don't think I'm over priced. Just need to find the right buyer that wants one completely re-done. If not I'll part it out later and probably get more out of it.
  4. Third time maybe http://s1282.photobucket.com/user/mforrest411/library/Banshee%20Build
  5. Never really used photobucket much. When I clicked on the link it didn't work, so I figured I would try another one. http://i1282.photobucket.com/albums/a529/mforrest411/Banshee%20Build/20140602_081644_zps58521145.jpg
  6. Up for sale is a completely rebuilt (top to bottom) 2001 Yamaha Banshee. It was completely taken apart down to the bare frame and everything was completely redone. There are ZERO rides on this Banshee since the rebuild. It was fired up and ran to break in the new motor, that's it. Per Kevin at HJR this set up should be making approx 80-85hp on 93 octane pump gas. The tires have plenty of tread left, there are no cracks in the plastic or rips in the seat. The graphics are in excellent shape and it also has a custom front grille. There will not be any joy rides at all so please don't waste my time or yours. Must have cash in hand! Asking $3,600 OBO. I have over 50 pics on photobucket (I hope the link works). http://s1282.photobucket.com/user/mforrest411/slideshow/Banshee%20Build This is a long post!!!! Here is a list of what has been done: Motor - All machine work and 4mil engine parts came from Herr Jugs Racing • Cylinders where bored and ported for a 4mil stroker motor, NEW Welded and Balanced 4mil stroker crankshaft, NEW Wiseco Forged Pistons and Rings, NEW gaskets and seals -$1099 • Cases were dipped, painted and ported to match the transfer ports on the cylinders - $75 • NEW Polished NOSS cool head - $195 • NEW Custom cut domes - $65 • NEW Chariot Reed Caged w/dual stage Boyesen Reeds - $165 • NEW Billet Water Pump Impeller - $78 • New Adjustable Timing Plate - $30 • NEW Engine Case Saver - $35 • NEW Stainless hex bolt kit for engine - $50 • FMF Fatty Pipes with Power Core 2 Silencers (Like New) • Pro Design Air Box Adaptor - $25 • K&N Air Filter - $45 • Carbs were completely redone, T.O.R.S. elimination kit installed and jetted for port work Transmission / Clutch Parts: • NEW Shift shaft, Adjuster screw, and Spring - $67 • New Pancake bearing for clutch - $30 • Shift Star Mod -$40 • NEW H.D. Clutch kit with Springs - $70 Chassis / Suspension: • Frame and swing arm were completely sanded down and repainted with 3 coats of paint and 2 coats of clear • Extended +2/+1 A-arms w/new bushings • NEW Ball Joints • NEW Tie Rod Ends • WORKS dual rate front shocks • Extended Stainless Steel (braided) front brake lines • Alum Brake Line Clamps • NEW Hub, Carrier, Swing Arm, and Steering Shaft Bearing and Seals • New Handle Bars and Grips • New Sprockets (Front and Rear) • New Chain Rollers (3) • New Chain Slide • DG Nerf Bars • DG Rear Grab Bar • DG Front Bumper Powder Coated Parts: • Front Bumper • Front Hubs • Rear Hubs • Rear Carrier • Foot Pegs • Rear Brake Lever • Kick Starter • Clutch Lever Thanks for looking!
  7. I ended up making one today.
  8. Let me know what parts you would want for a fair trade for the grille: Reed Cages with dual stage reeds Shift Drum with shift star Front brake lines (steel) Front brake hoses (from lines to caliper) Front Brake dust shields (all 4) Brand new Adjustable timing plate (cast, not billet) Stock rubber boots for airbox T.O.R.S with electronic box 2 ignition coils (needs boots and ends) Overflow bottle Left side engine cover
  9. Sent you a pm
  10. Looking for a stock banshee grille. Not looking for the whole radiator cover, just the grille. Willing to buy or possible trades for some parts that I have laying around. Let me know Thanks
  11. Everything is best offer. I want this stuff gone. Willing to make deal if buying mult parts.
  12. Lowered prices and updated parts list, showing what has sold. Stock Radiator - $20 Stock Carbs Complete with TORS and cable - $60 2 Chrome Grab Bars (excellant shape) - $10ea - SOLD Alum Front bumper (not bent, but used) - $20 Complete front brake lines and hoses - $25 Stock Cyl Head (excellent shape) - $30 Stock Cyl Head (pitted dome, not sure if it can be used or not, you make the call) - $10 Stock Reed Cages w/good reeds - $15 Shift Drum w/ shift star - $25 Shift forks w/shafts - $25 - SOLD Airbox Lid (notice 2 holes that were drilled for vents) -$10 - SOLD Left side cover (no cracks) - $12 Front fender brackets -$10 - SOLD DG Nerf Bars (old Style) needs new nets - $25 Air Box Boots -$7 2 Coils (need boots, got them in a parts lot a bought) not sure if they are good or not - $7 ea Tie rod adj sleeves (like new) - $15 - SOLD Complete set of front wheel mud deflectors - $15 Handlebars (no idea what bend) perfectly straight - $10 TORS with box - $20 Water Jacket that bolts to stock head - $5 Boost Bottle - Free w/purchase of anything else! Tail light (no mounts) - $10 Stock exhaust (missing one silencer)- Free to anyone who wants to pick it up! Chain guide (new in bag) - $5 - SOLD
  13. Stock Head and shift forks sold!
  14. Pm returned on head ans shift forks.
  15. Updated parts list: Stock Radiator - $25 Stock Carbs Complete with TORS and cable - $75 2 Chrome Grab Bars (excellant shape) - $10ea - SOLD Alum Front bumper (not bent, but used) - $20 Complete front brake lines and hoses - $25 Stock Cyl Head (excellant shape) - $30 Stock Cyl Head (pitted dome, not sure if it can be used or not, you make the call) - $10 Stock Reed Cages w/good reeds - $20 Shift Drum w/ shift star - $30 Shift forks w/shafts - $25 Airbox Lid (notice 2 holes that were drilled for vents) -$10 - SOLD Left side cover (no cracks) - $12 Front fender brackets -$10 SOLD DG Nerf Bars (old Style) needs new nets - $30 Air Box Boots -$10 2 Coils (need boots, got them in a parts lot a bought) not sure if they are good or not - $10 ea Tie rod adj sleeves (like new) - $15 SOLD Complete set of front wheel mud deflectors - $20 Handlebars (no idea what bend) perfectly straight - $12 TORS with box - $25 Water Jacket that bolts to stock head - $5 Boost Bottle - Free w/purchase of anything else! Tail light (no mounts) - $10 Stock exhaust (missing one silencer)- Free to anyone who wants to pick it up! Chain guide (new in bag) - $5 SOLD
  16. Fender brackets, chain slider, tie rod adj sleeves have been sold.
  17. Fender brackets, chain slider, tie rod adj sleeves pending payment
  18. Fender brackets, chain slider, tie rod adj sleeves pending payment
  19. Would like to get rid of this stuff. Open to offers. Willing to work out a good deal if someone wants to bundle some parts together.
  20. Updated parts list showing what has been sold. Stock Radiator - $25 Stock Carbs Complete with TORS and cable - $75 2 Chrome Grab Bars (excellant shape) - $10ea - SOLD Alum Front bumper (not bent, but used) - $20 Complete front brake lines and hoses - $ Stock Cyl Head (excellant shape) - $30 Stock Cyl Head (pitted dome, not sure if it can be used or not, you make the call) - $10 Stock Reed Cages w/good reeds - $20 Shift Drum w/ shift star - $30 Shift forks w/shafts - $25 Airbox Lid (notice 2 holes that were drilled for vents) -$10 - SOLD Left side cover (no cracks) - $12 Front fender brackets -$10 DG Nerf Bars (old Style) needs new nets - $30 Air Box Boots -$10 2 Coils (need boots, got them in a parts lot a bought) not sure if they are good or not - $10 ea Tie rod adj sleeves (like new) - $15 Complete set of front wheel mud deflectors - $20 Handlebars (no idea what bend) perfectly straight - $12 TORS with box - $25 Water Jacket that bolts to stock head - $5 Boost Bottle - Free w/purchase of anything else! Tail light (no mounts) - $10 Stock exhaust (missing one silencer)- Free to anyone who wants to pick it up! Chain guide (new in bag) - $5
