banshee9090
Everything posted by banshee9090
  1. pleas note i run stock timing!
  2. AK u useful help for banshee hq members is highly appreciate, if u can advice what is the safe compression to be used for (gas 95 octane),another way to what reading i need to decreas compression?
  3. thanks guys for the kind help as i said earlier i have no choice ,95 octane!is the higher octane in my place
  4. thanks man about u comment ,anyhow i can not find more than 95 octane in my country , i think no bigdeal between 95 octain in saudi araba and 98 octain in us! , octain calclation is international
  5. I really appreciate all advice man.
  6. Thank guys I already found the answer from old topic for AKheathen
  7. yes man with 2nd gear for about 10 meter race at home, decent power !!
  8. sorry elevatin is 2060 ft. also i run IV STAGE pipe!!
  9. i would go trail this week man i stil did not race with any, thanks
  10. I m plan to go dune this week , Now every thing looks ok with the bike, put one thing I doubt about , compression both side 190 + - 5 squish test is ok pleas note I run 95 gas do u think that is ok for dune 4mil porting 66.5 bore ,4mil 22+2 dooms elev. 2600 temp. wither 78 - 45 f , stock pilot jet 300 main jet stock carb , needle med clip, out side k&n air filter , stock sprocket, with stock cool heed comparison is about 140-130 if I remember witch cool heed is ok for this setup pleas.
  11. thanks for the good advice man.
  12. u are right man thanks for good advice.
  13. ya man i dismantled the cyi. i found the L sid intake port big beside the intake port in R that is why the temp.in L side morthan temp in R side i will try to keep them all symetrical, thanks man for advice
  14. yse the compression was even to both cylinders before break-in, i did the test again after break in i got 188psi R 180 L.now the ONE WITH 188PSI has littl emp. high ?ok i will map it
  15. I got my 4mil porting done,during worm up the motor I noticed the temperature and comparison of the left cyilnder is higher than the temperature and comparison of the right cylinder, I have shift to stocck cool head put still the left cyil. Temp. comp. is higher than the right cyil. what could be wrong , one or more port in the right cyil. is biger than other in the left ? any suggest pleas Pleas note With Stock cool head compr. Is 150 psi for left cyil and 140psi for right cyil. with Pro design 22+2mm dooms, have 188psi right cyil. 180psi for leift .
  16. in there [url="http://"]My link
  17. I got 0.043 - 0.047 squish test , After worm up the motor for 10 minutes I got 180 psi right cyil. 188 psi left cyi. what do think pal and there picture of what i did , in all project i spend 48hrs.4hrs almost per day dismantling ,learning, measuring cuting and testing ,after i got my broject done so far i did not go for racing i just run it at home, i plan to go duneing this week then i will feed back to you!! My linkMy linkMy linkMy linkMy link[url="http://"]My link
  18. sorry for duplicate it just test run!!
  19. My link
  20. My linkhttp://i1234.photobucket.com/albums/ff404/banshy2009/20101007081.jpg[/img]"]My linkMy link thanks man i will try it!! My link
  21. ok then ,I couldn’t able to post pice last time Maybe my membership not supporting download from the web but i can downlod from my computer to my forum gallery ! that time one gents member suggested me to send the photos to him then he will download them to the forum!! yse pal Let me get the squish test done , I will let you guys know how the banshee run with all details about what I did.
  22. i will do that soon!! thanks.
  23. 200 psi Before worm up the motor! I will check after breaking !I use octane 95 Where is the squish clearance is ?
