LT ROOKIE
Everything posted by LT ROOKIE
  1. The gears are fairly new. I only have about 4 full runs trying to tune the bike, so if I can buy the small gear only it should be ok.
  2. I broke a tooth on the small gear of my 2.68 straight cut gears. Can it be repaired or can I buy only the small gear?
  3. LT ROOKIE
    good stator
    Can u pm me his info or have him call me 954 662 9030
  4. LT ROOKIE
    good stator
    Looking for a good banshee stator with the newer style plug
  5. Pics sent. The cylinder is at Titan racing getting the stud fixed and domes cut
  6. 41 to 46 lectrons, any size in that range
  7. Asking 365 shipped with cable
  8. 39 pwk alky carbs with billet bowls. These are gravity fed with .122 dump tubes, .118 main, and 60 pilot
  9. What does it need to set them up for alky
  10. 1375 shipped for the complete topend and chrome Shearer bb/oof pipes shipped. I just stripped one of the head studs by over tightening it
  11. I have a set of chrome one out each side shearers but they are big flange. If u don't mind changing the flange I will trade you.
  12. 954 662 9030 sorry about that
  13. 14mm cheetah with 39 pwk alky carbs, 1-5 trans with billet second gear and output shaft, billet clutch basket with 268 straight cut gears, and shear oof pipes with silencers. Light weight stock frame with custom motor mounts and subframe. Quad has a lot of time and money invested. I'm asking 6600. Only thing I didn't get to do was add asv levers. Call or text mark for pics and I am in Florida
  14. 14mill 593
  15. Complete cheetah topend drag ported by a&s racing with v2 reeds, billet intakes, pistons, head/domes and Shearer oof drag pipes. Also includes the cases which are trenched and port matched to the cylinder. Asking 2000, call or text for pics. Selling to go DM
  16. I run a brake line from my back brake caliper to the handle bars using the front brake mastercylinder. My problem is if I slowly pull the brake lever there is no pressure. If i grab it hard it has pressure and works. Is this because of the long line or is there a problem with the master cylinder. I got the master cylinder used.
  17. He is in south Florida
  18. Where on the frame does it mount
  19. 85 plus shipping. I paid 150 plus shipping
  20. Got in contact with Dan and was advised to use a118 main, 55 pilot, and egq needle so i will try that. Dumps are 122
  21. I have a 14mm cheetah on alky setup for 1/8 mile asphalt. I'm running 39 pwks with an unknown needle and a 122 main. The bike is blowing a lot of smoke and sluggish off the bottom. What needle should I use? I am changing the main to a .120
  22. Me trying to tune it, I'm a beginner.I ran it today and its too rich so I will slowly lean it. What size cub do u have?
  23. I have a race cut fiberglass one that has never been used. It's the one the guy sells on ebay
  24. That's an old post. I got the motor back from tysin racing two weeks ago. I had him put the complete motor together. If it blows up, everything will be for sale
  25. I'm getting a trail bike together so I'm down. Hope you have a truck because we are going to have to travel.
