TONYMOMMONE
Recent Profile Visitors
464 profile views
TONYMOMMONE's Achievements
  1. i have links lying around. http://i1209.photobucket.com/albums/cc386/psopb2011/DSCF1279.jpg
  2. As far as i know, the frame is +5 and the arms are +1 forward and -1 in
  3. Not yet, it's on ebay and CL. They both need a good home and someone that can appreciate them.
  4. THIS BIKE IS A 2005 STOCK CHASSIS MODIFIED BY STELLAR. THERE IS A LOT TO LIST ON THIS ONE SO IF YOU HAVE ANY REAL QUESTIONS CALL ME TONY 561.723.3048 ENGINE: 12MM BILLET TWISTER CRANK, JUST REBUILT 130MM RODS, NEW BEARINGS AND TZ'S ON BOTH OUTER SIDES, CASE WORK DONE BY K&T. TOP END IS K&T PORTED 73.5MM BORE T-REX WITH 20CC DOMES, HAS AROUND 210PSI PER CYLINDER, NEW BORE, PISTONS AND GASKETS. STRAIGHT CUT GEARS, COMPLETE BILLET HINSON 8 PLATE W/ PUSHER, WCR OVERIDE 1-5 N-DOWN, STOCK FLYWHEEL AND STATOR W/ ADJUSTABLE PLATE, DYNA IGNITION W/ LAUNCH CONTROL (YOU CAN LAUNCH ANYWHERE FROM 6-10K RPM) PIPES ARE K&T BB BF W/ DIGITRON EGT SENSORS INSTALLED BEFORE THE CHROMING, CARBURETORS ARE 41 BORE TO 46.5 ALKY MUKUNI'S W/ DAVE MOORE POWER JETTS. MOTOR IS FRESH WITH A BRAKE IN PERIOD AND ONE PASS ON THE TRACK. CHASSIS: +5 IN FRONT, +8 SWING ARM, CHROMOLY SUB FRAME, STRUTTED REAR, FRONT MARVIN'S, FRAME IS IN GREAT CONDITION. I WOULD LIKE TO GET $6000 BUT I'LL CONSIDER REAL OFFER'S OR TRADES
  5. I HAVE $6500 IN THE QUAD. IF I CAN BRAKE EVEN I WILL BE HAPPY. I WILL ALSO EXCEPT TARDE FOR SPORT BIKES OR BIG CC CRUISERS OR OTHER QUADS.
  6. Taking offers, It's built for looks. It is a show stopper everywqhere I take it. I have around $6500 in it . 2006 with title, last year banshee.
  7. K&T IS THE BEST. I HAVE A 12MM T-REX PORTED BY THEM AND IT IS A BEAST. BUT IF WERE BUILDING IT I WOULD GO FOR THE DM.
  8. $300 to 33403 or trade for any banshee parts you may need. Tony Mommone Powersports of Palm Beach www.561powersports.com 561.723.3048
  9. I have a stock stroke cub with 65mm bore, new pistons, 1-4 m5&6 over ride done by wcr. All done by K&T, leme know. Tony Mommone Powersports of Palm Beach' www.561powersports.com 561.723.3048
  10. 2006 CUSTOM DRAG BANSHEE. ALL PARTS ARE BRAND NEW!!!! THE FRAME IS PAINTED BOWLING BALL ORANGE, ALL OTHER PARTS ARE EITHER POWDER COATED, ANODIZED OR POLISHED. NO EXPENSED SPARED. MOTOR - 4MM STROKER, DRAG PORTED OEM CYLINDERS, DIRECT DRIVE LOCK OUT & COVER, PVL IGNITION, WRC 1-5 NETURL DOWN OVER TRANY, VF3 REEDS, 35MM PWK, K&N FILTERS, 40MM RADIATOR. CHASSIS - OEM - NON CUT, DIRECT DRIVE WHEELS, +8 SWING ARM, MOD QUAD 40MM BILLET AXLE, MARVIN SHAW SHOCKS AS YOU CAN SEE IN THE PICS. THIS QUAD IS FRESH. IF YOU HAVE ANY QUESTIONS, CALL TONY 561.723.3048 IF YOU WOULD LIKE IT SET UP FOR THE DIRT, THEN I WILL INSTALL NEW DIRT TIRES ON THE SAME REAR WHEELS AND IT WILL COME WITH A DIFFERENT SET OF FRONT WHEELS THAT MATCH THE REARS. IT WILL BE NEW TIRES FRONT AND REAR. MAXIS OR ITP. ---- EXCEPTING OFFERS ----- THE BIKE HAS A NEW SET OF CPI OUT FRAME PIPES, ONE ON EACH SIDE. IT NO LONGER HAS THE PIPES IN THE PICTURES. THE CPI'S MADE MUCH MORE POWER.
  11. PLEASE PM OR CALL TONY FOR MORE INFO: 561.723.3048 ASKING $6500 OR TO PART OUT I WOULD NEED TO SELL MOTOR FIRST. MAKE OFFER ON COMPLETE RUNNING SET UP, CARBS, PIPES MOTOR. 2005 STRETCHED CHASSIS, CHROMOLY SUBFRAME, JJA AXLE, MARVINS, +6 SWING ARM, CHROME LIGHTWEIGHT ARMS, ALUMINUM TANK W/ DUAL FEED. MOTOR IS A 12MM TWISTER T-REX PORTED AND BUILT AND PORTED BY K&T. CRANK WAS JUST REBUILT BY CWI WITH NEW 130 RODS AND BEARINGS. 1-5 N DOWN WRC TRANY, COMPLETE HINSON BILLET 8 PLATE WITH PUSHER, STRAIGHT CUT, 200WT STATOR, STOCK FLYWHEEL, DD LOCK OUT W/ COVER, K&T BB BF PIPES W/ EGT SENSORS, DYNA LAUNCH CONTROL. CARBS ARE MUKUNI 41 BORED TO 46.5 W/ DAVE MOORE POWER JETS / ALCOHOL. I'M SURE IM MISSING SOMETHINGS BUT YOU GET THE GIST OF IT. THE MOTOR HAS ONE PASS ON IT.
  12. CALL SHAWN AT POWERSPORTS OF PALM BEACH WWW.561POWERSPORTS.COM
