Schweet97Z
    14
Everything posted by Schweet97Z
  1. Where are you located? I have a set of 04 LE Black front fenders unmolested in great condition up in my rafters I think I would let go. Sent from my iPhone using Tapatalk
  2. Looks good. What's the coupon code? I need to get some domes ordered. Sent from my iPhone using Tapatalk
  3. Forgot to update. Everything is sold. Thanks everyone Sent from my iPhone using Tapatalk
  4. You are correct. His bracket specifically for the coil under tank is ok. (As long as the CDI is not relocated close to that bracket) Sent from my iPhone using Tapatalk
  5. What do you get the interference from? The coil or the wire? If it's the wire you can try some feritte beads to eliminate the interference issue. Sent from my iPhone using Tapatalk
  6. Are they still available? Sent from my iPhone using Tapatalk
  7. I agree it helps...but wouldn't call it a scam if it works. Easier start up and better throttle response is ok in my book. There is a lot of marketing In the link I posted but need to look past that. Sent from my iPhone using Tapatalk
  8. This is a good read with some good info. http://www.nology.com/hotquest.html#Q10 Sent from my iPhone using Tapatalk
  9. Straight from Nology's website.... Question: Do I have to use non-resistor spark plugs together with HotWires, and what will happen if I use resistor spark plugs? Answer: To take full advantage of the performance gain possible when using HotWires, non-resistor spark plugs are best. If for any reason resistor spark plugs must be used, performance gain is less, because the resistor is impeding the spark, however, performance will still increase. Sent from my iPhone using Tapatalk
  10. Whatever floats your boat then. The plug recommendation is from Cody @ FAST. I bought the setup from them years ago just couldn't remember if I ran the BR or B8ES. Sent from my iPhone using Tapatalk
  11. Run non resistor plugs with the nology stuff Sent from my iPhone using Tapatalk
  12. Found my answer. This is just for reference for anyone else who might be looking... B8ES if you running pump gas or B9ES if you are running race gas. Gap plugs down to .020"-.024" Sent from my iPhone using Tapatalk
  13. What spark plugs should be used with the setup? B8ES? I'm assuming non resistor. Sent from my iPhone using Tapatalk
  14. I think the prices are fair. 2 full gallons sold. 1 full left and open jug. Rad cover pending? Sent from my iPhone using Tapatalk
  15. 3 full gallons - $40 a gallon shipped 1 OPEN gallon - $30 shipped. Alittle over 3 quart left in jug. ( see pics ) Black Maier Radiator Cover $80 shipped Sent from my iPhone using Tapatalk
  16. Just need T5's now Sent from my iPhone using Tapatalk
  17. Sent you a PM on the head
  18. Like the title says. T5's no stingers or silencers needed A cool head in good condition Sent from my iPhone using Tapatalk
  19. http://www.jdscustoms.com/product/rotopax-grab-bar-yamaha-banshee/
  20. Like the title says. I need the harness side plug. Or if someone can tell me where to buy one, that would be helpful.
  21. Am I asking to much for these? Why are they still for sale?
