ksw390
Everything posted by ksw390
  1. I figured so Sent from my SAMSUNG-SM-N900A using Tapatalk
  2. Special or limited edition is there any way to tell by the vin or is it all in what plastic is on it Sent from my SAMSUNG-SM-N900A using Tapatalk
  3. Only traded for it cause I wanted the motor gonna take the motor out and put in a stock frame I'm not a fan of drag frames not keeping the pipes either but boy does it run. Gonna post in trade forum later Sent from my SAMSUNG-SM-N900A using Tapatalk
  4. Michigan??? Sent from my SAMSUNG-SM-N900A using Tapatalk
  5. Traded predator 500 for it Sent from my SAMSUNG-SM-N900A using Tapatalk
  6. Sent from my SAMSUNG-SM-N900A using Tapatalk
  7. Extended the front of the bike and changed the back a little for those plastics I only got it cause of the motor Sent from my SAMSUNG-SM-N900A using Tapatalk
  8. Sent from my SAMSUNG-SM-N900A using Tapatalk
  9. That's what I was thinking it was cpi pipes carbs puke gas while it's running floats neef adjusted I guess but this thing flat out halls butt I might pull the motor and swing arm and sell the chrome j arms the frame is a crappy build the welds look good but just stupid looking to me Sent from my SAMSUNG-SM-N900A using Tapatalk
  10. Trade done delete Sent from my SAMSUNG-SM-N900A using Tapatalk
  11. Kinda of a crappy build on the frame but runs great. Need help figuring out what this top end is I'm thinking 409 big bore from la sleeve also what carbs these are size wise Sent from my SAMSUNG-SM-N900A using Tapatalk
  12. Just got this banshee runs great until you run wot. Pulls really hard through all gears until high rpm in 6th it seems like the right cylinder quits then it hits for a bit and pulls hard then quits again. Almost like a rev limiter lol it sounds like the right cylinder quits firing to me or stops getting gas I'm not sure. Any ideas where I should start. A little info tors delete pro circuit pipe jetted boost bottle starts on first kick runs great until 6th top end Sent from my SAMSUNG-SM-N900A using Tapatalk
  13. I'm in Northeast oklahoma Sent from my SAMSUNG-SM-N900A using Tapatalk
  14. I have a second engine that goes with this bike the second engine needs a top end the bike runs great has a 2005 motor in it the 2007 dropped a valve Sent from my SAMSUNG-SM-N900A using Tapatalk
  15. Must be 2001 or newer Sent from my SAMSUNG-SM-N900A using Tapatalk
  16. So its all in the cylinders nothing special in the bottom end if someone is trying to sell a saposed cheetah cub and it looks like stock cylinders with a cool head it's not a cub Sent from my SAMSUNG-SM-N900A using Tapatalk
  17. I know it's been ask and it was explained to me before but was several years ago and I have forgot. What is a cheetah cub what makes it what it is Sent from my SAMSUNG-SM-N900A using Tapatalk
  18. Is the factory banshee swing arm aluminum or steel I got a project in mind but that makes a big difference
  19. Ok so there is two banshees on Craigslist near me one is an 07 and the other is a 09 I know they still make it but how did they get them here in the USA
  20. I got some decent t5s had the on here for 250 shipped and didn't get any takers so I put them on eBay there sitting at 150 so you might get them cheap
  21. Check em out could be a good buy if they don't go up again
  22. Sorry man toomeys are already bid up too high to cancell the auction
  23. Put the hole thing on eBay see if it goes that way I'll cancel the auction if someone wants it for 500
  24. CPI's and toomeys both put on eBay
