malcman
Everything posted by malcman
  1. I just ordered the high flow impeller kit too, glad to hear it seems like a good piece
  2. You're getting fuel if the threads are wet lol, how old is the gas and what ratio did you mix it at?
  3. I hear ya, mine blew up the first time I had it out lol.
  4. Wow, deja vu much. I pulled my motor apart last weekend and have the exact same marks on my cylinder. I was missing a wrist pin cir clip on that side though which would explain my marks.
  5. PM returned
  6. TTT, lots of cases but haven't found any cylinders yet!
  7. I am looking for a clean set of matching cases, want a set with no damage, no chain break. Also looking for a set of stock cylinders with as close to stock bore as possible. Thanks
  8. Heal up quick boss!!!
  9. Ethanol in fuel is a scam but I'm not going to get into that haha. Ethanol mixed fuels have a shorter shelf life, and you should avoid letting it sit for longer periods of time. It will seperate and it also can hold a higher water content then regular gasoline, we just started mixing 10% ethanol into 87 and 89 octane gasoline at work. I only use Supreme fuel now as it does not contain any ethanol but they are talking about eventually mixing it in with 91 octane which sucks. Some people you talk to will say it has zero harmful side affects but I try and avoid it. They say it can damage gaskets and seals if left sitting for a while in your carb, etc.
  10. Rothesay, New Brunswick!
  11. Looking for a set of stock front Banshee rims in good condition, no bends, deep grooves, etc. I don't need tires, just looking for a good set of rims, looking for polished finish. Thanks
  12. I only use USPS when buying from the States, took me far too long to realize it though lol. I can't remember the number of times I've been hit with huge brokerage fees from UPS.
  13. I'm interested in the stock front rims/tires, can you snap a picture of each rim on both sides please? Just want to make sure there aren't any big dents/dings etc. Thanks, Andrew
  14. Don't know if this is the right spot but just wondering if anyone knows where to buy just the needles with screws? I have a set of carbs right now and the needles in them at damaged from the PO, I'd like to put new needles in them. Anyone have any advice, all the searches I do come back with a complete kit. Thanks, Andrew
  15. Did this with my YSR50 swing arm, worked well!
  16. LOL ya she's in tough shape, the bottom of my old airbox was smashed out from the P.O. bottoming it out.
  17. I replied in another thread but I'll reply in here as well lol. Ordered up a rear rotor since my stocker was toast, fit and finish on the JDS piece was spot on. I have zero complaints with the quality of the work and the overall experience with JDS customs.
  18. I'll add to the positive feedback for JDS Customs, finally had time to install my new rear rotor. The rotor has perfect fit and finish an nothing had to be adjusted! I'll definitely be doing business with JD again.
  19. Have fun with this one Matt
  20. Wouldnt think that arcing off the engine is normal
  21. Any better picture of the front and rear rims, looking for a stock set without any damage on them. Thanks
  22. I always stayed cleaner and drier when I ran with fenders than when I ran without.
  23. Have you swapped coils? if its got a lot of fuel in the exhaust on that side I would lean towards bad spark?
