bamaboybv
Everything posted by bamaboybv
  1. Lifts up 1-4 but it just hits a wall on top end WOT. Plugs are dark but dry. 28 pwks 150 / 50. Kn pods, dune port, +3 timing, ported stock reeds w/ TDR reeds.DMC 916. The kill switch was killing it because the button slides back and forth. Will the switch cause the drop of in power?
  2. Anyone got a dipstick?
  3. Still looking TTT
  4. Oh 700 ft elevation hot 85-95 weather
  5. Dmc 916 Ported stock cages carbon reeds +3 Kn pods w/ outers Dune/ light drag port
  6. Need stock studs
  7. Need reed bolts to the Allens for the cages
  8. Tank cover h20 pump cover , exhaust hangers (front) Good choke plunger 26mn stockers
  9. bamaboybv
    Top end
    I also need rear caliper, exhaust springs, exhaust hangers, that's all I can think of now thanks
  10. I need just the head pipes, cause my 916 silencers are ok. But I think ima jus save up and buy a new set at the price.
  11. bamaboybv
    Top end
    Need good set of pistons and cylinders prefer stock port but if you have any stock stroke setup let me know rhanks
  12. Washer with tabs, ill take all of it
  13. I need those 2 swingarm bolts that go through the carrier. And the tensioners. If you want to come off of those PM me thanks for your time
  14. Almost finish with a project banshee I need the following: Axle carrier thru bolts Chain tensioners (factory) Rear hub castle nuts Intakes for 28mm Clutch basket washer with tabs Pm me
  15. Ill take em Nieskes Still need rear caliper and rear hub castle nuts
  16. Ill take em Nieskes Still need rear caliper and rear hub castle nuts
  17. Got my crank and carbs. Still looking for rear caliper, crank gears, kicker idler gear with washer and snap ring.
  18. Also need the rubber motor mount pieces that go on the front and back of the cases. A bolt goes through them and bolts the motor to the frame thanks guys. I'm mainly looking for stock carbs no tors.
  19. Also need carbs, stock of 28s I need the throttle cable for the carbs. Prefer stock with tors removed
  20. I need rear caliper, idler gear and washer and snap ring, clutch basket, also I need 2 of the clutch basket nut washer( the one with the tab to hold the basket nut on. I have the nut loctited as of now) thanks
  21. Need upper a arm bolts thanks
