SpeedRacer88
Everything posted by SpeedRacer88
  1. cool thanks
  2. jus like the title says
  3. got one thanks
  4. anybody?
  5. i need a stator asap jus get me some prices shipping included not really looking to spend much but i wanna be running by sat
  6. with my mods do you think i wud benefit from a set of free 35pwks? or shud i jus sell them
  7. doesnt look to be the same to me way more info
  8. well i guess its a bog
  9. ok thanks everyone i got the air leak fixed banshee runs fine except no power around idle to 1/4 throttle pilot is 52 main is 150 i guess you can call it a bog... bike doesnt accelerate kinda hear nasally(like a nose) sound coming from the air filters please help he has the same mods as me except he has an generic(no name) trail port
  10. ok guys thanks for all the help found leak around the right intake... runs now usual amounts of smoke and exhaust out both pipes but now bogs around 1/4 throttle
  11. thanks guys so u guys think the smoke on one side is bcause of the air leak
  12. ok everyone thanks for the replys imma look for a leak 2day wen he comes back over but would a leak cause only one pipe to put out white smoke and the other pipe is just abiut dead read my original post for full story
  13. anybody? help please
  14. so u think we had a leak? where shud i look? how? wat about the smoke ?
  15. ok well i was helping my buddy do a top end rebuild on his bike(added timing plate +4, t5's 30mm oko's, removed tors) we got it all 2gether and it started the first kick then all of a sudden while it was idle it shot to half throttle i turned off the key and off switch pulled the plug wires and turned off the gas and it kept running for about 1min 30secs WTF!? so i turned on the gas jus long enuff to fill the bowls a little and started it back up again 1 kick. then noticed a lot of white smoke on left side... no coolant leaks even if revved the right side hardly put out any pressureso i let it idle and pulled up on jus the right carb slide still no pressure(i put my hand over the exhaust) out the back but the the engine did rev up...any ideas? im stumped carbs are synced also(i have nitrotate's video)
  16. flea bay
  17. thanks guys its the bigger one in this pic
  18. thanks for the help i got it out but now i dont have a bolt anybody got one? its got a special shank that holds the lever
  19. so i was installing my shift star after modding it and i was installing the bolt that holds the lever and spring i set my torque wrench to 8 because the manual says 7.2 ft lbs and as soon as i got to 8 my bolt jus sheared off leaving the shaft stuck in the hole... what do i do? can i drill it out and use a helicoil? with that hold it?
  20. pm sent
