SpeedRacer88
Everything posted by SpeedRacer88
  1. any stock cylinders??/
  2. ttt
  3. prefer to come with pistons paypal ready
  4. And you still won't admit that the were modified when I got them. I only started that post because I always hear every saying your reeds should match your intake ... I asked if I needed to match my intake I would never touch the pastic reeds. It's obvious that now you want me to return them so you don't look like the bad guy and that's fine I'll send them to you but I can post pics of the reeds they are broke on the lip wheee the two reeds meet no way I did that
  5. you had the big screws in them....i tried to install O.G. screws because the ones you had were to big for the pressure plate holes and they ended up widening out the holes. im not trying to be a dick man i just want you to admit to the fact that you knew you had altered them and didnt tell me before i paid for them. Why would i take the OG screws out and put bigger ones in there? that makes no sense my friend let me borrow his pressure plates thats when i realized the screws you had on that side were different. i already see you dot have the integrity to say you wrong and refund my money but damn at least admit you didnt fully describe them the way you should have.
  6. i know theres a wanted section nobody reads it tho, i've had shit in the wanted section for weeks then i put it in forsale and get a pm same day
  7. Paypal ready
  8. He ended a ebay auction and sold them to me saying they were in good working order. im not going to bash him i just want yall to read the PMs unedited. kadillacman reeds you sold me are missing a pressure plate bansheemandan my bad, i found it on my work bench and was wondering were it came from, i will send it out tomarrow, what is your address kadillacman ******************** ******************** kadillacman hey man 2 things 1. i borrowed a pressure plate from a buddies down bike, so please make sure you send it as he wants to be back up and running this weekend. 2. not even 2 hours of running them one broke and got sucked in the motor kadillacman after further inspections and spending 66 dollars on new petals i find that the cage itself broke. im at a lost here man i spent 5 bucks trying to find screws to fit the holes in the pressure plate because you had huge screws on that side so i spent 71 bucks for nothing the one cage is trash. im hoping you will make this right. bansheemandan there was nothing wrong with the cages when i sent them to you, if it was broke then you should of saw it when installing them, you must of over tightened them or something, they were out of my running quad with no problems, i am sorry but i can not do anything about wrong installation kadillacman Yeah and you never told me u lost the original screws and had two huge screws that are too big for the pressure plate and that the holes are now too big for stock screws to fit. I inspected them but where they broke there is no way that me over tightening or my installation could have caused. I can't believe your gonna sit here and say u don't have any responsibilty kadillacman I didn't bitch when I noticed the screws or the missing pressure plate, nor did I bitch bout the Reed that broke 2 hrs in, I ordered another set. But now I realize these cages are worthless and I want a refund I will be happy to send u back your reeds for free
  9. good call man that was the hose i had leak... the pipe had spent around a lil.... imma check that
  10. so a leak between impeller and trans can pressurize the transmission? my temps never rise, i can give that i try easier than crank seal
  11. well i had a hose leaking so i just fixed that and imma take a lil ride and see if i lose any coolant its white and foamy at the top of the lockout cover lexan, i never ran atf before so i didn't know it was supposed to foam up
  12. My crank was perfect I just had it apart 4 days ago new seals also leak down was good too
  13. I just got my bike back together, its my first time trying atf i bought a cheap walmart brand . through my lockout cover it looks foamy. it flows from both trans vents when hot. i have not lost any performance. havent fouled any plugs leak down was good im lost also temps stay between 160-180 on trail tech
  14. Gimme 60 bucks and I will
  15. No just a small piece of a delta 2
  16. paypal ready
  17. just found the problem sucked up a reed.. will it hurt my motor to just replace them or will i have to tear it down
  18. UPDATE>>> left side runs right side doesnt. swapped plugs and coil wires no change sprayed around boots no leaks as i can tell
  19. no i haven't done one i will put that on my list... thank you for the response
  20. Got my cub back together leak down held for an hour squish at .049 compression 165psi jetting 165, 52 CEL middle. Problem is it rode beautifully all day then it just started idling real high and just cutting out. it wont clear out i have a trail tech so temps stay low but weird thing is when it started doing it the rpms are jus reading really high now like 15,000. i have no idea what happen PLEASE HELP
  21. Just bought some VFORCE 2's i have the boss intake will i have to modify anything to get the best flow or will they match up pretty good? I haven't got the reeds to look for myself yet...
  22. set acquired
  23. set acquired
  24. paypal ready
