jar banshee 01
Everything posted by jar banshee 01
  1. thanks man! ya gonna put it on try it out see if i like it, if not its for sale. if it robs hp i dont want it on.
  2. been riding banshee since 01, i know if my chain lose or not!!! seen this thing bought it for 20$ so i thought what the hell i try it out! if you think i am a dummy riding with a lose chain your srewed in the head retard!!!
  3. dont ride to much moto cross. but do lots of jumping i herd it gets rid of chain slack, but i dont know. may be i will test it out
  4. Dose anyone like these things? Got one never put it on, any one have a picture of one on the bike. just want to see one on. thanks
  5. need cool head pump gas domes let me know. dont care what kind
  6. how much for the 2into 1 carb set up dont need air box and filter
  7. whats a good mesurment for the clearance if shaved 30 thou and at tdc
  8. how does a guy cut them bigger? or should i buy a cool head with big bore domes?
  9. hello all, ok just got the banshee bored out to 65 mm ,and the head is shaved down 30 thou will my domes on the stock head still work on the bigger bore of the cylinders? or does a guy have to re chamber them or get a cool head with bigger domes?
  10. picked up cool head was lookin at the domes but dont know witch size i need. is it bigger the domes less comp. want to run pump gas. thanks
  11. whats this guy using a stick or what?
  12. how much for adjustable timing plate, and tors removeal (carb tops, air screw, cable) maybe a shaved head? email is [email protected]
  13. better or not?
  14. what is an rz top end ? better then stock or what?
  15. got 2001 banshee dont think it an rz, what is rz top end what the diff thanks
  16. need a +4 axle, a +2 swing arm some carbs 32mm- 35mm +2 brake line front end, e brake cut off, adjustble timing plate and bunch of other shit yet
  17. want a +2 swing arm if any one has one to sell crome would be the i want but any will do, and need a +4 axle any make
  18. i need a set off 28 to 35 mm carbs and a cool head thanks!!
  19. what are you running
  20. i know 75/90 thick but its syn that i trust. you can crack your case and if your not too far from home you can make it. i was a good 15 km from home when i did it. no oil when i got home but she still wants to go. atf must be a little thiner oil that could be better not sure might have to try one day
  21. i would not run it
  22. i might be fucked up but why are your running tans fluid in your bike syn 75/90 all the way gear oil
  23. crush up a bunch of moth balls and stick them in there and go for a rip
  24. or any thing bigger then stock
