ngelati
Everything posted by ngelati
  1. V-FORCE!!! Im not using it but all people love it
  2. You are right!!!
  3. You got it bkabina!!! that is exactly what I have been told.... Are you runnig ProX pistons?
  4. flywheel nut (17mm).
  5. A lot of info!! --> http://www.bansheehq.com/forums/index.php?showtopic=27721 picture --> http://members.aol.com/ronw626/flywheel.html
  6. javier I bought the plug for my shee!!! 10 pesos
  7. I took out my fattys, I found a lot of carbon deposits inside it. Is there any chemical product to clean it? Or should I leave it like this
  8. It depends on the tipe of riding. I think that PT midrange are a great pipe and would work excelent with the cv carb kit!!
  9. I thik the 450 will win... Tell us who did win
  10. I used to use one of this (replacement of the stock) I never had a problem. Now I use a Pro design adapter with pro flow foam filter. It is so much better...
  11. Thanks again boonman!!! Man you are a bible !!!
  12. what is the diference between this two plugs? Can I use the 2nd one?
  13. thanks a lot!!!!
  14. I have a 20 fin cooler on mine. I Dont know if does any for cooling, but it looks trick !!!
  15. Hey boonman, how much (mm) can you take off the flywheel?
  16. I did a hole to one piston. http://www.bansheehq.com/forums/index.php?...opic=27929&st=0 Im gonna change boths (66mm - 370cc) Wich one should i buy? Wiseco, Vertx, Pro X ? What is the best?
  17. I would go higher on the main
  18. -2 works great for me!!!!
  19. I just bpught a used kit, off course i dont have any instructions. Can someone email me the intructions?
  20. tHANKS!!!
  21. thanks guys!! who is d34?
  22. Thanks richwuest !!! That is the info that I need !!!
  23. Long time ago there was a post about it. I did a search but I found nothing.. My shee is bored to 370 (66mm) Can I use blaster pistons? What rod should I use with this pistons?
  24. I mean diferences running one and other in the same motor...
