T-daddy
Everything posted by T-daddy
  1. thanks everyone i will be gettin a tap handle i wont be using a drill im 18 and shake like a old lady
  2. ok thats wat i wanted to no thanks but wen u tap them how is that done i have the instructions but it doesent tell u exactly how to use tap do i put it in the drill and drill it in or what how do u use it :geek:
  3. i know that but will it idle with just adding the tops and adusting it from the tops
  4. can the idle kit work with jus the carb tops with out driling and tapping the holes is anybody running there carbs like that
  5. thats wat i did but it dosent idle at all it was like this wen i got it all wires were disconnected
  6. i hear ya them ugly shits is in the way and causing problems they will be off by tuesday :cool:
  7. yea i will clean them to god nose the last time they were cleaned they need to be cleaned i noticed the floats are getting stuck open today it was dumpingas out of the tube ill repost on tuesday and let u guys no wats goin on
  8. yeah cross over tube on cant seem to figure out why it isnt idleing and i have the tors kit on the way should have it by tuesday i hope it helps
  9. if there switched from left to right will it idle or no
  10. how do u no if the carb slide are swapt from left to right (in the wrong carb but the half moon shape facing filter) what are the symptoms :geek:
  11. i have the same problem with my 88 right now it only idles with choke i dont understand it hope u figure it out so i could fix mine too
  12. T-daddy
    Rear Brakes
    ttt
  13. T-daddy
    Rear Brakes
    looking for rear brake setup whole setup or master cylinder and pedal
  14. im looking for a tors eliminator kit with idle screws thanks
  15. thanks sp will be replacing it asap
  16. thaks for the info and were do i get the seal from what is it called
  17. I found tranny fluid on the ground again i see were its coming from its coming from the gear shifter the whole were the rod slides in how can i fix it is there a seal there or sumthin
  18. could my airscrew be to far out and letting to much fuel in
  19. got a question can bad plug caps and old plugs effect idle it takes about three or four kicks to get started but it has spark and another question what causes oil/premix come out of tail pipes
  20. T-daddy
    wanted
    no dont got one yet but can i see pics of it
  21. T-daddy
    wanted
    sorry dont need modified airlid just plain
  22. T-daddy
    wanted
    ok thanks man
  23. T-daddy
    wanted
    sounds good to me have any pics
  24. T-daddy
    wanted
    looking for air box cover with snorkle or with out thanks Trent
