T-daddy
Everything posted by T-daddy
  1. ok thanx trex
  2. lol it isnt that hot i could put a finger on it for a few sec but is it normal for it to be hotter then the pipes during warm up
  3. might be a dumb question but during warm up wen u let it idle do the cylinders and the stock head supposed to get hot like real hot hotter then the pipes is that normal
  4. thats another idea ill try in the morning any other ideas :biggrin:
  5. i tried all sorts of pliers and vice grips even tried extractor but didnt try cutting a slot any other ideas
  6. i tryed to take stator cover off but one of the screws is stripped how the hell can i get it out
  7. nope just wondering
  8. is this a good tranny oil to use this is it and what is the amount of fluid i need to put in
  9. could i use jet kit :geek:
  10. what tranny oil is pink :geek: and is it good to use no leak tranny fluid mixed with your tranny oil
  11. and what causes an mis fire or backfire
  12. where would i purchase main jets
  13. could the leak from were the pipe connects to the cylinder cause this because wen i rev it up smoke comes from a little spot near the pipe oring do i need no rings and springs
  14. i need help with jetting mods:fmf gold series pipes, DG silencers,boostbottle,pro flow adapter/airfilter with no lid current jetting 200 main 25 pilot clip stock at sea level and its about 40 degrees what should my jetting be at
  15. the bulbs are fine the regulator should be good and my switch is good what could it be i have a ricky stator its fairly new i think its a 200w could it be bad already causing the lights not to come on
  16. i finished the installation of the tors it was pretty damn easy the hardess part was getting the airbox off to get the carbs but i have another issue it has a sort of popping sound coming from the pipes not loud but u can here it wat causes that could it be bad plug caps or plugs
  17. what do u use to file down the carb boss
  18. heres a link to the lghts i brought off flebay lights
  19. i just grabed one from the dollar store ill let yall no the results brb
  20. its running but wen u kick it over with the light switch on shouldnt they atlease blink
  21. ok the only ground wire is the one on the voltage regulator is that right in the back buy the regulator and cdi what blue wire hooks to the regulator the one but the cdi plug up or the blue wire coming from buy the statorwires
  22. ok ill try that
  23. i got some new lights but wen i pluged them up they didnt come on its like the switch dont work or sumthin i dont get it its the head lights
  24. yep i have wd40 ill use that :cool: will do thanks for the tips DAJ
  25. will they have the lubricant and tap handle in a hardware store
