Ricehater
Everything posted by Ricehater
  1. I was trying to be funny ... anyone think he should buy a new chain??? duh.... !!!!!
  2. You should add a boost bottle to your setup
  3. how much for the girl who's head is cut off in the picture.....??? i am looking for a girl like that ... so she cant talk back
  4. I think "fuel injector cleaner" might work.... but alot of these products dont work ..... i have no experience with octane booster cleaning things ... my opinion is this..... gas is one of the best cleaners i have used to clean anything... brake cleaner works better.... if you want to clean your fuel system take it apart spray some brake cleaner on it and dry it off.... :biggrin:
  5. it will not clean anything .. its safe to use but unless you added timing or compression you will not need extra octane and you will not see any performance gains
  6. Any tank that will get you around 120 psi ok .... the problem is.... lets say you want to use a cutoff wheel.... it cuts good for about 10 seconds then you get to take a brake for 2 minutes while its building pressure ... i use my tank alot and the waiting kills me You will be fine with either of those tanks and that impact but if you plan on using them alot spend the extra money
  7. I am just saying that if you do anything automotive a good impact can make your life alot easier... i think i spent 150 on my impact and i have had bolts that it would not remove if you are just using it for your banshee you will probably not have any problems ... i would spend the money on a good torque wrench
  8. that compressor will work fine but..... the problem is air tools use alot of air and the smaller the tank the more you will be waiting for it to fill back up ... you might loosen one bolt and have to wait 2 minutes for it to build up enough pressure to loosen the next one and a good impact wrench is priceless buy a good one and you will be VERY happy buy a cheap one and you might as well not even have one
  9. like he said ..... the engine has to be loaded ... not just reving
  10. you could try these sites too .... www.Ball/lickers.com www.Teabags4mymouth.net
  11. I read an article in super chevy (i think) they had laboratory tests done with all the popular octane boosters... the results were terrible... if i can remember the best one raised the octane from like 91 to 92.5 or something they're not worth the money
  12. I was looking in orange county craigslist and saw this ad ... banshee parts and yfz parts he has polished upper arms 75$ candy blue powder coat lowers 75$... i would buy these but i need red http://orangecounty.craigslist.org/mcy/445113303.html
  13. how much weight is that spring for? i could use a heavy duty one :beer:
  14. i've never had mine "too deep" i use the pull out method ... i dont want kids!!! i have more expereince with v8 engines ..... but water doesnt compress very good and can damage cylinder heads and pistons.. so if i went too deep i would shut it down take it home and drain fluids
  15. i'm just joking... Pods are a type of air filter that you replace the stock air filter with to improve performance... take your seat off and see if there is a big black box(stock filter)
  16. i will work on the size of my sig hahaha i didnt realize.. but you're right its too big i used a drill press when i did it... first i milled the bosses flat and then drilled.... i dunno why they turned out like that... i have done alot of machine work ... maybe my drill press is out of round i can still tighten them down but they just seemed too loose
  17. Why you hating on your shee..... making it go through water??? :sad: If you have the stock air box you should good as long as the snorkle doesnt go into the water If you have pods ..... stay outta the drink
  18. When i tapped the idle screw holes i noticed the screws were really loose... like the bit was one size too big??... anyone have that problem????? i used a kit from vito's and it included the drill and tap...... ::
  19. This bumper looks best !!!!!! :biggrin:
  20. Sorry to ruin the mood with that video.... it was scary to see... makes me think twice about riding ... i have fun on my banshee but that is not how i want to die...maybe he was being an idiot but still....... we've all been idiots at some point .... shouldnt have to die because of it
  21. if you can still see the philips pattern on the screws... you might try this http://www.harborfreight.com/cpi/ctaf/disp...temnumber=37530
  22. He should loosen his chain up it looks wayyyy too tight
  23. it has " ball joint front end " i wonder if i could replace my front end with some of those ?!?!?!?!?! are "pro taper grips" even worth mentioning??
