sa3ood_banshee
Everything posted by sa3ood_banshee
Where Could I Re-locate My key
sa3ood_banshee replied to 350BANSHEE350's topic in General Banshee Discussion
^^gd point .i think u should go for it sa3ood -
ok great picss,but what does tha parking brake block off plate do?? thnxx sa3ood
Having Problems Starting My Banshee
sa3ood_banshee replied to osoloe1's topic in Banshee Repairs and Mods
ya ur choke is spoiled,i think u need to replace some parts in tha carb.what r those parts i have no idea sa3ood -
lol as long as ur in my country so tha elevation is same,(sea level) so i think u should start with a 320 and check, btw were in uae r u??? if ur in dubai i think u should do tha jetting in dubike tha best,if u dnt no themm i can go with u,im there daily customer sa3ood
btw u have 4 snow tires,size = 22,10,-9,they have like a million paddle thingy's dnt u thats over killing???????? sa3ood
were are u from?????? uae by any chance :biggrin: sa3ood
oh yaa!!! thnxx man i think ill get those instead sa3ood
sup guy, ssrry for this annoying question but i really need haulers, and my builder and parts dealer( tha only one around) has only 12 paddles haulers, tha size is i think 22.11.8(not really sure ,but maybe almost)so du u guyz think i should go for it,my shee is stock i really dnt wanna mess with tha sprockets(changing them) cuz they dnt have tha case saver in stock incase they tighten my chain alot thnxx sa3ood
hi guyz i want to put neon lights on my shee,i wanted to know that will it work without batteries,cuz all they need is 12v power supply,but not sure for each light a 12 v or for like 3 or 4,anywayz u guyz think it wiil work,and i want them to start with my lights only. thnxxxx sa3ood
how do i flush out old coolant?
sa3ood_banshee replied to 1996dragshee's topic in Banshee Repairs and Mods
so did everythng work out well???? sa3ood -
1. remove tha radiator cover( tha grill thing) 2. place a container under both tha cylinders,then remove the drain bolts(one bolt on each cylinder,its in tha middle) 3. remove radiator cap(on top of tha radiator) 4.remove reservior cap (under tha seat) 5. disconnect the hose on the coolant reservior side and drain the coolant even from there. 6.after everythng is out(coolant) rebolt tha cylinder side bolts( one on the left side and one on the right side,located in tha middle of the cylinder) 7.reconnect the reservior side hose 8.pour coolant in tha radiator untill its full. 9.install tha radiator cap then run the engine several minutes,then stop engine and check collant level in tha radiator,if it is low add more untill il reaches the top of tha radiator. becarfull let tha shee cool before opening tha radiator cap or u could end up burning ur self 10. then fill tha reservior till maximum level 11. install tha reservoir cap and let tha shee warm up a little 12.go out for a ride :biggrin: cylinder coolant side draining bolt torque: 10 NM(1.0 m.kgf, 7ft. lbf) im not responsible for any of ur mistakes or damages done by you, this toturial was taken from the yamaha banshee service manual,and i have done it a coulpe of times without any problems, and if ur having trouble i can post up a few pics. gd luck sa3ood -
yo man i tried registering on bebo put the varification pic is not showing (tha code thing u have to copy to prove that ur not a computer program registring) thnxx sa3ood
revers start?
sa3ood_banshee replied to felcon edition banshee's topic in General Banshee Discussion
lol so it seems shee doesnt like walking backwards :wink: :wink: :wink: sa3ood -
ohh thanx for the relief guyz, i started to get worried,i think im gonna put in 2 quarts rit now,i dnt fell like getiing tha ball welded to that long thing(iv seen in one of the posts) thnxx a million all sa3ood
sup guyz i just changed my shee'z oil,and to what u no the oil capacity is 1.5 liters,anyways i think i put alot more than 1.5 liters,only a few ml more ,its my first time,and i didnt have a measuring cup( mom would kill me if u took hers ).lol, so is it okay or should i drain it and put tha same oil back in 2 recomended capacity,thhnnxxxx a million sa3ood
lol i think a agressive dune port is much cheaper,i thing u should just port her man and plz dnt tell me u dnt no wat porting is sa3ood
thnx man i really appreciat ur help,unlike other ppl who wont post 2 wordz and a pic sa3ood
yea man it verry easy and dumb once u understand were r all tha parts located,i used to nagg when mods with jetting used to show up on my mods list,its verry simple and eassy,i cant seem to find tha toturial of changing jets(with pics),i hope som1 else posts it up gd luk man sa3ood
k guyz im gonna go buy new rear tyres most probably haulers,but if i get confused i think im gonna go for tha itp ones(v shaped),but i want front tyres to complement my sand setup,i want somthing that i will notice a diffrence in,wats tha best,i searched and got help,lplz tell me what to get,and i think telling me tha names wont help,i will need pics to see tha kind.thnx i really appreciat all ur help guyz sa3ood
yes u have to rejet,u cant argue with anyone on the topic cuz no jetting =lean,ur engine is starving for fuel,and as jbrooker said,ur can even end up with melted pistons,so what du u think is better getting ur jetting done rite or having a top end rebuild i hope this helps Air filter Remove snorkel:1-2 sizes larger on the mains, adjust airscrews Remove airbox lid:1-2 sizes larger on the mains, adjust airscrews Add foam air filter:0-2 sizes larger on the mains, adjust airscrews Add K&N air filter:4-6 sizes larger on the mains, adjust airscrews, add one size on pilots if necessary Add 2 into 1 Foam air filter OR dual carb-mounted foam filters (removing entire airbox, NOT in addition to removing snorkel and airbox lid above):2-4 sizes larger on mains, adjust airscrews, add one size on pilots if necessary Add Dual K&N carb-mounted air filters (no airbox, NOT in addition to removing snorkel and airbox lid above):4-7 sizes larger on the mains, adjust airscrews, add one size on pilots if necessary Add Outerwear:no change i think u should even read this :biggrin: http://www.dfn.com/benkaren/jetfaq.html i thank a fellow hq member for the link sa3ood
who does chrome plating?
sa3ood_banshee replied to 1996dragshee's topic in General Banshee Discussion
mine is in the sig,its show chrome,and i can get u a closer pic if u want sa3ood -
i alwayzed like your sand setup climb any hill,it amayzing sa3ood
k now what should the tire size be and how manny paddles,im not gonna dragrace,just screwing around and playing in sand,but i want a gd setup without changing tha stock gearing,btw ur alwayz welcum at my pl ace man edit; lsn man im gonna go to sleep now ill reply ya tommorow,its freaking 3:00 am here sa3ood
k thx for tha info 2,but now im confused,btw were in uae have u been,and next time u cum 2 tha uae we can go ridding shee'z sa3ood
so what du u think 6 paddles or 8?? im running a bone stock shee
