1966nova
Everything posted by 1966nova
  1. the plug looks little brownish/black doesnt look to lean or rich? im comparing it to my race car plugs? ive kicked it 6-8 timeas at least.. would it still run wot good seems to pull hard,on that low off compression.. i mked the jugs honed cyl installed new pistrons/rings the .std....what else would make low compression thanks
  2. shows 80 on both cyl? but 3 weeks ago i honed cyl and put new rings and pistons in it just for maintince and my gauge read 75-80 lbs also so i believe my gauge is wrong? because the bike starts every 1 kick very easy?ill try another gauge tommorow i didnt think it would run on that low compression am i wrong???
  3. thanks im new to banshees and the website is exxclnt.... i have a 01 with +4 timing,20.thous shaved stock head,fmf fattys,im in dallas tx i think were below see level. i also have k/n pod filters no box,jeff at fast sold me a jet kit,i jeeted it from 200 to 300 on mains and left stock pilots and needles.... this bike was all stock it seems like it was faster all stock it has a problem off idle boging then picks up and runs wot perfect seems just idling around it is a slow no response at all ,also flutters at low speeds and a few backfires... im wondering if its the pilots??? ive adjusted air screws from 1 out to 2 out no difference....it feels like no torque...my friend has a 01 with fmf ssts and shve head his is VERY responsive and fast ,mine is very bogy down low feeling... im losing ideas wat to do the bike starts perfect every time plugs are a little bronish im thinking pilots???the kit came with 30 jets only.. i have no air leaks and the tors box is unplugged,new plugs,i thinking my carbs arent adjusted perfect??????????? thanks please advise
  4. 1966nova
    stator
    i need a stock stator for my 01 my bolts came loose and cut the wires to it sat afteroon thanks greg
  5. just bought some parts like a timing plate k/n pods... jet kit his service is EXCELLENT very nice and fast to call you back very helpful i would also highly recomennd thanks greg
  6. i have a 01 banshee with reed valves vitos and fmf pipes very mild port work all rest is stock with just open filters no box and 4 deg tim plate im very new to banshees it has stock jets also im in dallas tx..... i would like some advice on which jets????? also 20 thous shave head the carbs are stock jeff at fast rec 300 on the mains???? thanks greg
  7. the jets are stock and needle setting never have been touched also the reeds are closing all the way it just feels diffrent shouldnt it be more peppy???
  8. i forgot also stock head 20 thous milled.....
  9. i have a 01 banshee im geeting ready for my fmf pipes it is stock very mild port and 20 t hous shave head stock carbs with vitos reeds i installed the reeds with stock exhaust and it seems like its more bogging feeling??? are they junk reeds???? or should i use the stock ones.. i just want a bike with alittle more power than stock and this is my first banshee???? thanks greg which reeds would be good or my vitos reeds good......im using stock cages also
  10. i have a 01 banshee with reed valves vitos and fmf pipes very mild port work all rest is stock with just k/n filter with no holes cut in the box? should i cut holes in the box? im very new to banshees it has stock jets also im in dallas tx..... i would like some advice on which jets????? thanks greg
  11. please chk pms i would like them thanks greg
  12. pmd you ill take them thanks greg please email me to let me no if you have them and how to pay you thanks [email protected] or 817-905-1393 im in dallas tx
