505chevelle
Everything posted by 505chevelle
  1. I am looking to buy a set of carbs for a 4mil, drag port banshee with CPI inframes. My question is, has anyone tested lets say a 34mm flat slide mikuni to a 33 or 35 pwk keihin? I have noticed alot of people with the keihins. I have ran alot of smaller mikunis (28mm) before on dune bikes and have had great luck. What are the real differences between the two? How do you size the carb, RPM, CC's of the engine, how radical of port duration? Can some one point me in the right direction? Also, I have already searched this, and pretty much everything I have seen so far is- Put this carb on there because this guy said so. Thank you :biggrin:
  2. What color plastic? I have black and live in Oklahoma city. Heres my bike with them- if you are interested call me 405-519-6493 Chris
  3. The first thing I would say to do is to speek some clear english. I can't really tell what your question is. :cool:
  4. So did you try to run it before selling the jugs, or did you sell them because everyone says jugs ported for stock stroke won't work? Finished a bike last year that has jugs ported for stock stroke, guy didn't have the money to buy new and have ported again and the bike flys, made 78 hp @ 10,000 little sahara in OK last fall. I know dyno numbers are just numbers but, the bike really runs great. Had Jeff do a duneable overide tranny and the bike will out run a few of the cub motors that go out to little sahara in OK. Just sayn you might measure the port work before you just go from "word of mouth" and sell a set of ported jugs.
  5. thanks man, thats what I will do. Anyone got some stock porting jugs, don't really care if they need to be bored or not they will get it no matter. and with that being said my jugs are standard bore and would be a great bolt on for someone that dosen't want to spend alot.
  6. Thanks thats what I wanted to know, My port timing is at 196 right now, can anyone tell me about how much it changes with the stroker crank? Thanks, chris
  7. I have a set of jugs on my stock stroke engine that have a good drag/dune port. My question is how exactly will it effect the power range that my bike has now if I go to the 4 mil stroke 5 mil long rod crank. do I need to use a spacer under the jugs for anything other then piston to head clearance because I can cut domes for that. My main concern is port timing and how different it would be. Thanks, Chris
  8. black with alba graphics, Did you have out of frame pipes?
  9. In Oklahoma, Yes.
  10. Thanks guys for the info, Still thinkin on doing the cub motor, but would need to do some tranny work right, thinkin that dunable overide. you can still use it as an normal tranny as far as down shifting, is that right? would like some one to explain that very well, as do's and don't with the dunable overide. got a quote for f.a.s.t and really thinkin about going that route, thanks chris
  11. How much for the water pump impeller? send me a PM
  12. would like to end up with 65-75 hp and not have an all out drag bike that I can't take in the trails and on a mx track, maybe that clears up "ridable". What would an as cast port 421 cub make power wise with good carbs, v-force 3 on race fuel?
  13. mine runs fine, I don't want an all out drag bike.
  14. want to buy it? I have a 4mil stroke 5mil long rod crank sitting here, should I port my jugs or buy cub 421? want a cub but want it to be ridable.
  15. I can get him on asphalt and the bike really runs decent but that wasn't the ? on the pipes. so......
  16. I've got a bike with CPI in frames, stock carbs tors removed, boysen rad-valve, cool head with 18cc domes, timing at +6 and NO porting. I'm about 165 lbs. Should I use the +6 swingarm that I already have or stay with stock? and what tires with what swing arm? want to kick the shit out of this 700 raptor with cams and bunch of other stuff. :thumbsup: for sand drag , thanks
  17. I have a steel 1"X2" rectangle tube +6 swingarm for stock rear carrier that is gloss black. Would like to trade for a +4 that is equivalent. Can get pics If anyone is interested. great condition never bolted on. also would sell for $170 shipped. I take paypal.
  18. No, already lookin to buy something else. would be a good deal for someone :biggrin:
  19. So whats the deal here, call me and I will buy it. 405-519-6493 chris
  20. yes I know it needs work, anything other than maybe a clutch, the cover leeks and silencers need packed. Is there anything else? If it needs tuning or even new carbs No problem. When will you know if this other guy is going to buy it, cause I've got cash$$$ now. What town do you live in so I can get directions?
  21. Then sell it to me now! :biggrin:
  22. Dude, I will pick it up at your door for 1650, If it is what you say it is. lets do this :thumbsup:
  23. looks like little rock AR. would be close, give me a call
  24. Let me know what town and zip code, I will mapquest it and find out. I could travel this weekend if we could get this deal going.
  25. I would give you 1800 if you would meet me half way to Oklahoma City. If your interested call 405-519-6493, Thanks Chris
