desert nut
Everything posted by desert nut
  1. just spin and bang spin and bang bang bang and lube lol
  2. take the nut off soak it with lube take 3 pieces of 2x4's and a sledge hammer and pound the s out of it i promise it will come loose 3 pieces because at least 2 will break by the time you are done
  3. i have a set of toomey tr6s one of my ends on silencers is loose behind the snap ring could it be packing or part missing, i bought them used if it is part where can i buy
  4. i am runnin' stock carbs no tors toomie t6's checked slides looked synced re adjuster carbs but not sure if it is 2 turns out or 1 1/2 turns out w/t6's
  5. got runnin' fine no longer for sale
  6. got working ended up being f$%&ed up mechanic left my flywheel loose
  7. could be seal i switched plugs and also switched plug wires from left to right and vice versa but still the same but feels like it runs fine
  8. ohm out the stator and if it test ok it could be your ground or flywheel came loose i just dealt with the same deal
  9. my shee smokes more on the right kicker side than the other side and also that side pipe gets hotter than other :ermm: i got toomeys t6's can any one help :: checked spark and both sides spark the same please help
  10. have banshee front stock a arms front shocks spindles brake calipers and rear shock for sale or trade need a cdi and wire harness for 97 or newer i also have front brake lines front shocks and rear stock swing arm
  11. how much? nice pic too funny
  12. i am looking for harness and cdi not cut reply with price perfer 97 or newer also have lots of shee parts stock a arms swing arm hubs front and rear brake lines and calipers
  13. do you have a wire harness and cdi if so how much
  14. will you take 70 bucks for wires
  15. looking to sell or trade needs cdi dox has neww toomie t6's need pics email ,me and i will send some
  16. had no spark replaced coil stator no spark replaced cdi sparked fat took out for test ride no spark again :: so that makes 2 cdi's whats next???????? gas and a match WTF please help me 1996 banshee 350 :verymad:
  17. i had the same issue with my '96 shee i changed stator and coil but it ended being the cdi i bought a ricky stator cdi it worked great
  18. have you checked the pilot jet it could be clogged the happened to me and my pilot jet was clogged
  19. found problem the cdi i put on was bad replaced it and good as new
  20. i have a 96 shee it ran well 1 day parked it 2 weeks later no spark i changed the coil nothing :: next i changed the stator still no spark :: :: :: replaced cdi and checked wire harness replaced plug nothing can anyone fnhelp me
  21. my 96 banshee runs like a champ but if i turn it off i need to be pulled by another bike to get it to start only mods are toomy t6's and larger jet it ran great when i parked it 2 months ago i cleaned both carbs and dumped old gas also put new plugs please can anyone help me am ready to light it on fire!!!!!!!
  22. i think i found the problem since i am used to 4 strockes i was not sure what to look for to find the problem but i cleaned the carbs and noticed the hose from one carb to the other carb was missing not the fuel hose the one for the choke. (duh) when i replaced it , it fired right up still runs a little rough but just might need a little fine tuning thank you all for your help
  23. just had new rings put in but it has a weak spark but when it starts it runs great is it possible the stator or coil ????
  24. i have a 1996 banshee when i kick it does not start but if i pull start it will run great but when it stops it wll not start back up i spray starter fluid in carbs and it starts but when it stops i cant kick it to save my life please help????????????ready to sell
