Thumper7999
About Thumper7999
- Birthday 03/27/1979
Contact Methods
Website URL
http://
ICQ
Location
Merrill, WI
My Banshee (optional)
1989 - Red w/grey - Sold 2006 SE - UNI filter, lightened flywheel(boonman), modded shift star(boonman) +4 timing
Thumper7999's Achievements
How wide to get to 48" OD on the stock rims?
Thumper7999 replied to turbowrenchhead's topic in Banshee Repairs and Mods
You scared me. I'm from Wisconsin and I just picked up some new tires and rims that bring my width to 50". I found this post while looking to see what (if anything) I'm gonna break having the tires hang that far off the axle. I did a little digging, and they changed it from 48" to 50" a while back. http://dnr.wi.gov/news/weekly/Article_Lookup.asp?id=1284 On a side note, I haven't found a good solution to the license plate requirement, just a functional solution. Have you found a good place to mount it? -
I finally broke down and picked up a tors removal kit, and will be installing it in the next week or two. I've never used a tap, however I have seen them used a few times, but I have a few questions. What kind of lube/oil should I use and where can I get it. I've done some research, and gotten answers ranging from wd40 to engine oil to 3 in 1 oil to specialty aluminum cutting oils to beeswax. Also, any tips/tricks for using a tap? I'm fairly mechanically inclined (gotta be to love a banshee) so I don't foresee it being a problem, but I prefer being as prepared as possible before I tackle anything new. Thanks for the advice in advance. Also, any tips/tricks for repacking silencers or just follow the instructions? (first time for that too)...lol
I'll be trying to get the stuff to repack them in the next few days...I'm normally not available during normal business hours, so it could be a bit. Thanks for the advice, and I'll let you all know how it turned out. I know it was kind of a silly question, but I was a little worried about it...feel much better now.
I was wound out in 6th, moving quick, then pulled off the trail into a parking lot/intersection/play area, saw some smoke behind me on the trail, then I revved the motor while looking at the tailpipes and had a truly massive blow of smoke come out (filled most of the intersection). I shut it down to think and have a smoke, and when I restarted it...no smoke at all, and none the whole way back (about 30 min.) the time in the mudhole this spring, I went into it in 4th, came out in 1st with the nose in the sky for the last 30-40 feet (the hole caught me offguard...loggers make messes in weird places)
running 32:1...haven't changed that in a long time. I do blip the throttle when I wind it up...never feels right to hold it wide open for more than a few seconds at a time...something I've always done and never known why. I just checked my owner's manual...couldn't find anything about repacking stock silencers...I did pull them apart though...cleaning the sparky was listed. very oily in there, with not much burnt on buildup. looks like that could be it...so do you think the oil in there from just putting around w/ the kids, or is there something else wrong. what would be the easiest way to clean it out? If there is no major problems, I would favor an hour or 2 going up and down some of the high speed trails over cleaning by hand. thanks for the ideas...keep 'em coming...I would like to be pretty sure what's going on, so any new ideas are welcome
This will be a long explanation for a simple question...sorry in advance. I went on a ride a few weeks ago, and towards the end of the ride, I noticed that It was smoking from both pipes a little. I bought this 'shee new, and other than a little smoke on startup, it rarely smokes...normally only when putting around the yard for 30 or more minutes giving the kids rides, and then only a little. It got me thinking about a ride this spring, went through a long mudhole, cranking on it pretty good, and when I looked back there was a cloud over the hole. I wasn't sure I saw it, so I didn't think anything of it till now. I went out for another ride this week, and decided to take the same route as last time...found a great stretch of trail, and wanted to make sure I remember where it is. I got to the same place I noticed the smoke last time, and when i turned around to look, there was a HUGE cloud behind me. Right before that, I was on a nice stretch where I had it pinned in 6th for about 30-40 seconds. There was no smoke before that, and after shutting it down, taking a 5 min. break, and getting going again, there was no smoke the rest of the way back to the trailer. Most of these trails are 4th gear, jump/turn/jump again/climb a hill kind of trails, so I was riding pretty aggressively all day. Power felt perfectly normal...never missed a beat. Is there something going on with having it wound up in the high rpm's that would cause smoke where full throttle at lower rpm's for shorter times doesn't, and I just never noticed it before, or am I looking at having to do some motor work? (my guess) I bought it a little over 4 years ago new, and the motor has never been opened, so I'm expecting to have to do something to the topend soon, just based on time ridden. If I do have to do some work, any ideas what I should be looking at first? I'm torn between hoping shee's perfectly ok, and pretty sure shee's starting to show her age. Thanks for any advice and help...I gotta make sure she's 100% by the middle of next month...I'm taking a week off, and I can't afford to make it to the ride with everyone at little sahara, but I will be camping and riding that weekend a little closer to home.
Thanks guys...helped put my mind at ease. I'm not riding it until I get that clip replaced, but I'm glad I didn't do any damage...cleaning is easy and cheap, and I had planned it anyways. TORS removal is on my short list...just haven't gotten around to it...guess this is the spur I needed to get it done.
Went on a ride today....took it easy for the first hour (riding partner's recovering from having his kidney taken out and not supposed to ride at all), took a break (idling normally) then took off nice and hard by myself for about 10 min. When I got to an intersection on the trail and slowed down...noticed that it was idling REALLY high. I looked it over and found the right carb cap completely off and dangling (TORS leaning weirdly) I put the cap on and tightened it by hand the best I could and took it easy getting back to the trailer...took about 25 min. I stopped to check the cap every couple of minutes...and it didn't come lose again. My figuring is that the cap could have been off for up to 10 min., but probably less than 2 min. I was in clean air through this time period (no dust/water/mud/etc.) It started right up after putting the cap back on and idled normally...no smoking from either pipe. It seemed to run fine, but I basically crept back to the trailer, so I didn't get to check how the power feels. Started up fine when I got home too. Any idea if I did any damage, what kind of damage I might have done, or what to look for in the future as far as diagnosing any damage I did with this ride? Also...does anyone have a spare little piece and screw from a stock carb that locks the cap on the right carb....mine's laying in the dirt somewhere.
first ride of the year could've gone better
Thumper7999 replied to Thumper7999's topic in General Banshee Discussion
I love that quote myself...one of the best. I asked my friend for permission to post the pics and vid...don't wanna step on his toes if he doesn't want them up or if he wants to put them up himself. He did put them up on facebook, so I think he's ok with sharing...should have them soon. I'm dieting right now...I told him having organs removed was cheating. -
Thanks for all the get well wishes...he appreciates it. He's home now, and in his last update to me was whining about "making love hurts"...lol. He still can't stand up completely straight. He's gonna be fine, doctor told him it will be 6 weeks before he can ride again...so he will be trying in a month I'm sure. (he doesn't like to be told he can't do things) His scar is truly impressive...there is a vertical line by his right kidney, and they wrapped a line around his front, over his bellybutton, and just about to his left side...it goes about 3/4 around him. -
final update...he ripped his right kidney in half and lost 3 pints of blood before the surgery, but didn't puncture the skin. They took the kidney out, and they are keeping him for 5ish days for recovery and because they are worried about his liver...they think it's fine, but it's very close to where there was some major damage. He's out of the woods, but it's gonna be a long recovery. -
I'm not sure how you fracture a kidney...but that's what the doctors told his fiance right before they took him into surgery....they were saying puncture before that. He actually asked to go to the ER....said he wanted them to give him some vicodin...I actually didn't think it was that bad until he started shaking when we got close to town. -
update...he has a "fractured kidney"??? It is being removed. -
Thumper7999 posted a topic in General Banshee Discussion
The local trails opened yesterday, and my riding partner and myself got out today for a few hours. Beautiful weather, machines running great, and about 4 hours into the ride he pulls the bonehead move of all time. He pulled out his camera and started taking video while he was riding. He's done this before, so I wasn't too worried, but while we were on the road between trails, he decided he wanted video of his quad riderless. He swung his leg over and stood up both feet on the right footpeg, leaned out, and started taking video of his quad instead of paying attention to the road(driving with 1 hand, camera in the other). It took less than 30 seconds for him to creep toward the ditch, and when he realized it and jerked away, he fell/jumped off, hit the ground running in the ditch (about 25mph), fell headfirst and rolled, and landed like a pretzel. I checked him out, got his quad out of the ditch and running (kickstarting a 450r that isn't jetted right is a bitch), and we limped our way back to the trailer, loaded, and got him to the hospital. He didn't look to bad...some road rash, torn pants, and maybe some bruised ribs...but it was almost 2 hours from the crash until he got to the ER, and he was going into shock by then. There were some cut 1" trees in the ditchline about 12-18 inches long, and he thought he missed them...he didn't. Internal bleeding, puncture in his kidney, and a "flight for life" trip to a trauma center about 50 miles away. They say he's going to be fine, but any wellwishes or good thoughts would be appreciated. One bonehead move, and him and his family are going to have some problems for a while....kinda sucks. After watching him crash though, I can guarantee that his helmet saved his life, so there's something to be thankful for. (p.s. when he gets the video uploaded, I'll get a link to it here) -
DO NOT Deal with Sprocket Specialists
Thumper7999 replied to locogato11283's topic in General Banshee Discussion
Personally, I greatly appreciate the heads up about the customer service. I believe that you can tell a lot about a company by how it solves problems, and treating ANY customer poorly is inexcusable. I decided a long time ago that I won't spend my money with a company that can't take care of it's customers.
