TOYBOX
Everything posted by TOYBOX
  1. Shearer small bore out of frames, one per side . PM if interested.
  2. Exit one per side, plated, some flaking, $350 o.b.o. Buyer pays shipping.
  3. PM sent.
  4. Want to buy YELLOW front fenders race cut or full fenders OEM plastic only.
  5. Been running 50:1 hp in my R's and the shees, interceptor is a waste in a shee unless your powervalved, great in the sleds though. I'm not a fan of Klotz, but the flexdrive 30 I've had the best results in my drag bikes and hillclimbers, I an Amsoil dealer and I do not like the tranny oil in a heavily modded shee.
  6. Want to sell that 85 Klemm?
  7. Is it for the 4.6 or 5.4?
  8. If you can find a clean Graydon inake, go for it!
  9. Ohtsu was the original make on them on the old ATC's, I bought 2 pairs, old stock from my local Honda dealer $45 a tire.
  10. I'll check on one of my spare motors to see if I have one
  11. I have one, deciding to keep it or not, it's all there but needs a complete resto.
  12. What are you doing with the chassis parts?
  13. Get a small chisel and put it on the outside edge of the screw and tap it in a counter clockwise motion away fom the case. Hope this helps!
  14. Post a pic! I have an 86 atc, 88 R, and 89R , my avatar is of my 88.
  15. There is a yellow conduit-type cover over the one wire in there. Check the stator bolts and for any play on the flywheel.
  16. Watchin the game right now, go Steelers!!!
  17. Check out TRI COUNTY ATV, drags held 2nd Sat. of every month, Heilwood PA, Mini, take 119 to indiana, then 403 at cylmer to 553 toward Penn Run. About 50 min.
  18. Follow the above on the jetting except, if you don't have ported cylinders go 170-178 on the main
  19. Hello, A friend of mine had his 2 Blasters stolen and they tried to start the banshee and flooded it. The bikes are both white and black. One bike is heavily modded 2000 and the the other is a bone stock2002. Both bikes disappeared in Carrolltown, PA at 5am. Let me know if you guys hear anything, thanks!!
  20. What I'm gettin at is let's help the guy, maybe I miss interpreted your reply, maybe I didn't. I'm tryin to help him. I'm not being smart but I own 4 R's, 2 shees, zilla, and a t-4, plus 2 sleds, by the way I also have a shop. One other thing a R has that acts up is the counter balancer, if it has a bad bearing it will let the crank to come out of balance.
  21. I only own 4 R's, you tell me
  22. Crank moved in and out, the R is known for the crank to get play between the lobe and inner bearing race
  23. Heard a whine from my 88 bottom end last week, crank bearing were bad, it was moving enough to make it break up on top end.
  24. I trail and drag my bike, but I'm using a Graydon 2-1 intake with a 35pwk air stryker. I had dual 35 pwk's before, great for all out dragging, but they sucked in the woods. As far as topend, I gained at least 8-10 mph on top with no bogging doing slow in the woods.
  25. Dido, on the R, my 4 mil doesn't pull my R until 450 ft, and not by much, I'm run 310 ported, 41pwk, and ESR whale pipe.
