fryball2001
fryball2001's Achievements
  1. i can shift up on my bike but i cant shift down can you give me a hint on my problem. can you tell me the cheapest place for 33mm carbs the whole kit
  2. I have vforce reeds port polish 2 in 1 38mm carb cpi inframe 18 cc domes in coolhead run c12. bike run great until i hit 5 and 6th gear it starts to bog whats the problem need help.
  3. thanks for help
  4. boring .90 over is this good and what do u think i should do
  5. 18cc, run mostly open fields and drag a little
  6. do run 93 pump full race fuel or 50/50. what type of race fuel to run
  7. i have duncan racing power heads do u have to buy ducan racing domes or what other domes or compatible with these heads
  8. it idle good and revs good but when i put in first and go it bog then she runs great
  9. i have 2 into 1 38mm kehin carb port polish coolhead 19cc reeds. now when i hit throttle it lags untils it hit powerband then she runs great can u tell me whats wrong so i could get my throttle response back
  10. need 33 pwk or 34pj with intakes
  11. I live in south louisiana so my elev is low ill find out if i have timing today. i do run wot for a little while. but sometimes i dont but im getting a compression tester today. so ill let u know what it reads
  12. Do u think i need race gas to be safe and i going to by compression tester today
  13. it has mild port polish vf reeds and have 38mm 2 in 1 carb and by the way what i have to do to convert back to dual carbs
  14. i think 20cc run 93 octane runs fine through all gear but hesitate at top of 6th but thats were i think my plugs started to unscrew
