rrr
Everything posted by rrr
1 day left
Pm or email sent back to everybody
I will take pictures and answer PMs tomorrow. :thumbsup: Thanks
Could do, Shoot me an offer in pm with your address. I will give you a price for your exact address. Will be cheaper for you. thanks
I have a lot of parts that needs to go. Most of them are stock parts comming from a 2003 banshee. Need to get some space and money to complete my rz banshee project, stuff as to go. All prices are without shipping. If you want something, just pm me with what you want and your addres and I will send you pics and a shipping price. - 1 race cut yellow front fender 40$ - 1 gas tank with the valve and cap 30$ - 1 rear shock white spring 50$ - 1 rear shock linkage 20$ - 1 complete wiring harness with CDI, coil pack, voltage regulator without TORS crap (2000) 150$ - 2 headlight covers (yellow and red) looks like two eyes 10$ - 2 rear hubs 20$ - 2 Cylinders ported by RG would need to be resleeved, awsome porting 150$ - 1 clutch basket and pressure plate as some groove in the basket 30$ - 2 boots for profoam filters plastic 10$ each - 1 rear caliper 20$ - 2 front shocks white 80$ - 2 stock foot pegs 20$ - 1 brake pedal 10$ - 1 rear brake fluid reservoir with cap 5$ - 2 stock tie rods 10$ - 2 front calipers 40$ - 2 upper tabs painted red 40$ - 2 front disk protectors 15$ - 1 front brake line the metal part going around the rad 20$ - 1 front brake lever 20$ - 1 stock skid plate 10$ - 1 rear carrier bering and seal need to be replaced 15$ - 1 rear disk hub and disk 15$ - 1 rear sprocket hub 10$ - 1 stock front bumper mint black 20$ - 1 swing arm stock I think it's bended but not sure 10$ - 1 stock handle bar 15$ - 1 set of cases rod broke and hitted the front of the case on the magneto side I think they could be repared but not sure Make offer - 1 stock tranny was going perfect but the sprocket nut was welded on the output shaft so I had to grind it, Would need an output shaft, gears were shifting well make offer - 1 drag ported motor was on a trail bike, every seal and gasket was replaced during rebuild, topend at p1 (wiseco pro lite), as rolled maybe 20 hours since new topend, head was leaking replaced for a straight one, front end was lifting in 3rd gear, porting looks rough but is pulling hard 800$ - 1 33 mm keihin carb was run on alcool with trinity 2 in 1 setup would need new seal and new pin Make offer I am forgetting stuff... Pm me for pics
I Don't have a picture of the one i'm selling because it was never installed. You can see what it looks like on duncan racing's site. It's the black and gray one Duncan Racing's site
Duncan Racing seat cover ebay This is my first auction on ebay, I have to much banshee parts in the garage and need to get rid of some of them. Tell me if the auction sounds right or if there is something I should change! I have almost a complete banshee in parts, so feel free to ask if you need something. Thanks
Thanks man, I'll check my oil level. If anyone else can think of something say it, I wanna try everything before changing the crank seal.
I don't think it's the crank seal because they both work fine until I reach top end, then the clutch side cylinder stops and heavy blue smoke starts to come out off the pipe as if it was not able to burn the gas, the other cylinder works perfectly all through the powerband.
Ok so here is the problem: when I reach top end my clutch side cylinder just stop working and heavy blue smoke comes out of the pipe. I changed my spark plugs and switched my wires and it was still the same cylinder that shut off so I guess my problem is in the carb. I am currently running 360's on the main, 27.5 pilots 1.5 turn out, needle on the second clip strating from the top and my setup is : pro circuit pipes, top end port job and I am running on the stock air box and filter with the snorkel off and stock carbs. This thing rips my arms on one cylinder I wonder how it will do on two
Fatty pipes, Air filters, Jets & other misc.
rrr replied to Hilarious's topic in For Sale - Parts & Accessories
Thanks for the hint on the jets I was mostly looking for pilot jets though -
I ll try this, it's my only solution
I would be interested in the jets only if you want to sell them seperatly, do you have some pilots jets? Pm me to let me know -
I just tried a 13 tooth front sprocket and remove the lower tensioner and that ****** chain still wont fit . Anybody else bought this kit from magicracing? Racer Kit - Yamaha Kit Includes: JT Chromoly Steel Countershaft JT Steel Rear EK520SRO O-Ring Chain Chain Tensile Strength = 7400 lbs I asked for stock gearing Do you guys think I could grind my swinger to make the adjustement go looser? Any of you as done this, just strechen the holes where the bolt slides?
How much do you want for that air box, would you sell only the k&N adapter? Pm me
If it's not allready sold to fuzzy I'll take it all
I think I will try to get a smaller front sprocket cause I tried everything . 104 links with the adjustement to the tightest gave me something like a 6 inch slack and 102 links with the adjustement to the loosest gave me an inch between each end and could not connect it I checked with my old chain and I had 102 links but the links are not even the same size so I guess it stretched. I have no clue what is the problem with that chain
I just bought a chain kit from magic racing: the kit included two sprockets 14/41 supposed to be stock gearing and a EK 104 links o-ring chain. I installed it on my stock shee and without cutting it I could not get a chain slack under 6 inches so I cutted a link and now it just wont fit there is an inch between the two end and there is no way I can connect them . Anybody now what the problem is ?
Ready to part out or not yet? If you do pm me pics off the axle
Ebay link What do you guys think?
If you only need the bottom part of the case, I have one that look good. The rod hitted on the top case but the bottom should be fine. I will check if you're interested. Pm me
99 Banshee with title being parted out.
rrr replied to broke's topic in For Sale - Parts & Accessories
How much do you want for the sandtrix motor and pro circuit pipes? -
alright, im street legalizing my quad...
rrr replied to superang's topic in Banshee Repairs and Mods
I'm in Quebec and I wonder if the laws are similar? Tell us when youre on the road Would be awesome if you could make a turorial!! Is it registerd as a custom built vehicule? Do you have pics of your Shee with all the street legal stuff on it? -
No it's 64mm
Where are you located in Canada?
