smokincycles
Everything posted by smokincycles
  1. not sure but i opened the exhaust up on my cyliders about an 1/8 inch id, and polished them up with a rubber type dremmel stone,now i can tell the difference in longer harder pull down the road,,,and a crisper trottle response on the bottom end....other than that i have twin k&n filters with a 290 jet,,,i think im gonna bump up to a 300,and the 310 was just a little to much,,,it was boggish on bottom end,,,and i have fmf pipes in which i would rather have t-5 toomeys
  2. i used a red plastic folgers coffee can,,,,,slips over real nice,,,,maybe add 2 zipties to keep it all the way against the carbs,,,,,,quick cheap fix,,,,try it out and let me know if there is a better way
  3. I WROTE BIG SO YOU COULD READ IT AFTER ALL THAT YOU HAVE BEEN DOING....THATS BAD FOR YOUR EYES I HAVE HEARD ,,,,,LOL,,,,,I WILL POST PICS SOON,,,,OR PM ME YOUR EMAIL AND I WILL SEND A PIC ... THANKS
  4. I GOT THIS BIKE FROM A GOOD FRIEND SO I KNOW IT IS IN GOOD RUNNING AND RIDING CONDITION...LOOKS GOOD RIDES GOOD....JUST NEEDS A RIDER,,,,I DO ALL KINDS OF TRADES,,,GUNS,,,SNOWMOBILES,,ANY A-ARM BANSHEES,,,ALKY CARBS,,,SANDRAILS,,,CARS,,,TRUCKS,,, WHATEVER PM ME AND LET ME KNOW WHAT YOU MIGHT SWAP
  5. just lookin for the best deal
  6. what alky carbs do you have,,,,,
  7. throw me a deal im in 46350 area code for shipping
  8. IM STILL LEANING TOWARDS CRANKSEALS AND MAYBE EVEN A BAD CRANK ONCE YOU GET IT APART...THIS IS WHAT MINE DID...ONE PIPE STAYED COLD....REVVED LIKE A BLASTER... NOBODY WANTS THAT...IT EVEN CHANGED SIDES ON ME AND THE OTHER WAS HOT AND THE HOT ONE QUIT FIRING...NO MATTER WHAT I DID SHE WOULDNT RUN RIGHT...IT EVEN RAN ON EACH CYLINDER ONE AT A TIME WHEN ONE PLUG WIRE WAS OFF THE OTHER SIDE......HAD ANOTHER 01 BANSHEE TO TROUBLESHOOT WITH SO I CHANGED COIL-CARBS-REEDS-CDI BOX-STATOR-REMOVED THE TORS-REMOVED PARKING BRAKE-RAN IT WITH NO SILENCERS-PULLED THE JUG TO INSPECT THE COLD SIDES PISTON-SO WHAT WAS LEFT--RIGHT,,,,GET THE GUN OUT AND KILL IT....SO I WAS CHANGING THE CRANKSEALS AND FOUND I HAD A SLOPPY CRANK TO ADD TO MY MISERY....PUT IN A USED CRANK AND NEW SEALS AND SHES A SHEE AGAIN....RIPPIN LIKE IT WAS NEVER BROKE....IF IT KINDA SOUNDS LIKE THAT TRUE LITTLE STORY I JUST BORED EVERYONE WITH TEAR IT DOWN,,,PUT NEW SEALS IN IT AND GET AN OPINION ON THE CRANK WHILE ITS OUT....DONT FORGET TO GET SOME YAMABOND FOR THE CASE HALVES
  9. 01 banshee needs a +2
  10. i had the same problem,,,my crankseal was bad,,,,right side plug had a slight gear oil smell,,,i had one cold pipe so i swapped parts with a buddy untill crankseal was only thing left,,,problem solved
  11. i want to advance my timing a smidge,,,how far do i go ,,will it hurt my engine,,,will i pick up hp on top or bottom or both
  12. im getting ready to buy a new set,,,,i have had t-5 series and i loved them,,,i currently have fmf fattys,,,,but i think im just a toomy man,,,,so i need to know from an experinced t-6 person if they are worth the extra bucks compared to the t-5 set...
  13. ok,,,heres the deal...i have a 2001 banshee with bad crank bearings...so i want to do a stroker kit,,,timing plate,,,lightened flywheel,,,modified shift star,,,prodesign coolhead,,,,domes depending on crank setup,,,stock carbs in the winter with k&ns no airbox...lectron alky carbs for summer,,,, possible 4 in over swingarm later on,,,we only ride on weekends,,,,normal trails ,hills,down the roads,,,through shallow creeks,,,,silverlake and the badlands,,,i just want to be the one with some roostability...for about $1500.00 to $2000.00,,,,which parts and mods do i want for the biggest bang for the buck.. and the best places to get the parts without getting ripped off,,,.please help before i buy the wrong combo...i need some options,,,.thankyou
