momo20
Everything posted by momo20
  1. well its all the parts are here and i am putting the shee back together...what is the best type of tranny fluid to run...the bike is gonna be a stoker +4mm so i dunno if that matters....i just want some top quality fluid in there
  2. yeah i guess they hold the bearing in place.....i need a part number and how many a banshee engine has...so i can order some
  3. how many are on the banshee enigne, and how much are they...thanks
  4. thanks
  5. me and my buddy are putting in my stoker crank and while we are doing that we are switching cases due to a broke rod in my last bottom case going threw the case...but when we go to switch the gears over the shift forks....if you are on the back side of the case with the crank in front, the side with the two shift forks, they look the same but they have a one and a two on the different ones, so where does one go and where does two go, i got the side with one shift fork on, i just got the other side messed up ....thanks
  6. ride a banshee with aftermarket pipes...then you will be sold...notting like the sound and power of a banshee
  7. momo20
    yfz shocks
    so did u notice a difference in the shocks??? was it worth it??
  8. i have it but never played on line...i will make a user name and meet you guyz there sometime..my user name will have something to do with my car like stealth or twin turbo...something like that
  9. momo20
    yfz shocks
    i would like to see some pics of the modification if possible.....i want to do this...cause i have a feeling with the stoker kit in the engine i will want a bette suspension
  10. momo20
    yfz shocks
    i really dont want to spend the money on the shocks from works or elka....they are a very nice shock just a little out of my pirce range right now....what other shocks work with the shee
  11. momo20
    yfz shocks
    i have a 1987 shee...as some of you may know i have been doing a lot of work to it lately..kinda like a restore project...overall the bike is in really great shape...the frame is straight..but i want to do something different with the front end as far as shocks go...will the yfz shocks work...like a direct bolt on with little to no modification....i am gonna get the sterring stab. from noss...just want some better shocks..thanks
  12. bump
  13. i want to get a general ideal on the amount of HP i will have in my banshee...here are my mods white brothers boost bottle hot rods +4mm long rod crank with 6550 pistons port and poilsh toomy t-5 pipes uni foam filter with open box high flo coolent fan cool heads with 21mm domes
  14. i have a 1987 banshee....the guy who owned it before me put on of those dead man switches and removed the headlight/kill switch....tonight i went to put the headlight/kill switch on, but i am not sure what whire go where..i know to match the colors up,,but i need diagram for the stock headlights and how they hook up and into what color of wire....also the wires coming out of the dead man switch are white and black...i still want to hook it up but i think i am gonna splice it into the headlight/kill wires...so i need to know what color wires control the kill function on the bike...thanks
  15. wtf are you talking bout
  16. cost??????????$$$$$$$$$$$$$$$$$$$
  17. i need a headlight/ kill switch for my banshee....any year will work....must be in fair clean working condtion....i need one asap...thanks
  18. wow..i hope the best come and you get either your crank or your money work
  19. i just bought the uni air filter of ebay....not knowing i would need more parts... i still have the white part of the stock air box...the part the air filter sits on...just not the cage part
  20. anyone know?
  21. i bought a uni foam filter due to the K&N failing on the bike..costing me a rebuild....but my bike did not come with the stock air filter cage( i guess that is what you would call it) so does the uni filter just chill on the intake peice or do i need the filter cage???
  22. are you talking bout the lt250r? my brother has a 1987 and it in mint condition..but my banshee still ownes him
  23. what kind of pre mix should i use.....is Golden Spectro Premix ok or should i use yamalube?? i have the weisco stroker kit ...with the cool heads..either 19 to 21 cc domes
  24. i need a banshee headlight switch...the one that controls the kill and the headlights high and low beams...one in fair condtion...would be nice....thanks
  25. i want to put a nice blue looking blub in my stock headlights.....what is the max i can run with out hurting my quad..... does piaa make anything like that??? thanks
