islandsurfer
Everything posted by islandsurfer
  1. I called the dealer I bought the SHEE from and they are looking for the guys number to call him and get exactly what he did to the SHEE... After i find out, I will decide...Nobody has really answered what i asked yet though
  2. I ordered a 14 tooth for the front... This should help then???
  3. I have dual 35mm trinity carb w/ manifolds and would like more low end grunt for trails and MX... Will it be worth it to swap or sell what I have now for the single carb set-up??? Or will the set-up I have now be better for all around riding??
  4. When I raced last weekend I couldn't shoot out of a turn like I needed to... I bought the the SHEE used so I am learning more about each time I clean and ride it... I noticed it has a 17 tooth front, what should I go to to help me out...17 front 42 rear and 22"tires... I want to be able to pull harder on the lower side because the track I frequent is a tight track and I ride a few trails too... Thanks
  5. Good to hear everything worked out in the end!!!!!!!!!!!!!!!!!!
  6. Alright... 4th time ever on a quad in a MX track ever... First moto on a canyon jump I went off the side and got sucked under my left tire, and push the Clutch lever down... But I had to finish for myself... So as I painfully still go around the track while having to reach over the bar to use my clutch, I finished 3rd...2nd moto, I bogged and almost died at the start had a pretty good run and came in second...What a GREAT day.... The track is tight and I need to get use to clutching more... So not only is my whole body sore, I also have gashes in my arm from when I went off the side of the canyon... I lost to a Z400... Oh well I will get him next time...
  7. I'm Rick Jame Bit.....I am sorry , yes ma'm, I will do the dishes and fold the laundry... <--- famous last words-----
  8. Thought I heard background music when i was reading this....
  9. What gear where you in on the good set of doubles?? Thanks for the advice I really appreciate it after seeing what happened...
  10. Thanks for all the advice .....Practice is on Saturday and the race is on Sunday, so I am going to get as much seat time as I can to work out any jitters and uncertainties on the jumps and get use to taking the turn faster...I wanna to get the whole power slide thing down...
  11. I am in lower AL... I have a DS80 2 stroke with an extra motor...not perfect but working for $450
  12. I don't care what any body says... My SHEE is great at what I think it is great at.... It's as good as my poor ass can afford to make it...
  13. I measured the carbs accurately and the size is 35mm... Big boy Banshee: I changed my plugs and now both sides work.... I had to play with the idle screw about 2 1/2 turn out and now it idles... how do you now if its to high??? the air screw I turned out 2 1/2 turn also, now I have to do a plug check but I don't have anywhere to open it up to 6th gear any suggestions??? Could this be moved to the jetting forum.... Thanks
  14. I am racing the local track here this sunday... gonna bring extra plugs and Titanium NUTS just incase I foul them.... Any advice from you racing Vets out there...
  15. It can modded to take the YFZ... But it will depend on whether you can take a YFZ...The SHEE will do her part, you just have to do yours....
  16. I bought new pilot jets and ended up with 5 extra, more then I need... I have 55 pilot jets... anybody want to trade instead of buying others....I am sure it can be mailed thru and envelope and a stamp....there are for a KEIHIN and the brand is DG... Thanks
  17. I called Trinity and they told me to go with 55 pilots... gonna try it at the track this weekend...
  18. I have the carbs... I just want to intake and throttle cable... I am willing to make a trade a complete set for a complete set... I have the trinity stage IV dual carb set with 35 MM, boost bottle, cable (thumb), intakes and K and N pod filters with outer wear...
  19. That SHEE cost more then my jeep...
  20. Alright ... have to wait till tuesday... the dealership is closed sundays and mondays here.... Thanks
  21. I bought it used... i figured it was high, when I saw the number.... I don't know to much about the Shee.... All I know is what I see... I was told there was engine work, but don't know what kind... So if I goto a 45 for the main it won't run so rich and will idle?? It spit globs of oil out the back and the plug was wet and black... Thanks, also where can I get a pilot jet?? does come in sets or can i get it seperate??
  22. here are the numbers... 78 pilot:65 main:165
  23. There are local races around here in Lower Alabama, but the ATV class is not that big... looking for anyone near here, Ft Rucker, Al.... Thanks
  24. I have a question.... I have 22" rears and stock gearing, I want alot more low end grunt for MX and trails, what should I get?? I opened the spread sheet and I noticed it lower the front , the lower the speed... Will going down a tooth in the front and up a tooth in the rear give more power to the wheels on the low side or just make me shifter more?? Will doing this relieve alot of the clutching I have to do in the turns?? THANKS
