Running Engine $1000.00
Rubber intake boots/Boost $30.00
Reeds and cages $20.00
Carbs and cable $100.00
Airbox (or air filter) $50.00 - $80.00
Kickstarter $50.00
Gas Tank $30.00, $15 for one with bad fenders mounts
Pipes $35.00 stock - $300.00 chrome aftermarket
Frame components
J Frame $100.00 (title add $100), A-arm frame, $250 (title add $100),
Steering stem $25.00
A-arms / J-arms with brakes, hubs, spindles, and tie rods $300.00
Swingarm $50.00
Axle $100.00
Bearing carrier $60.00
Footpegs $10.00
Nerf Bars / Metal Heel guards $50.00, add $50 for plastic heel guard pieces
Rear Hubs $50.00
Rear Sprocket & Hub $15.00
Rear Brake disc & Hub $15.00
Dogbone $10.00
Rear Grab Bar $20.00
Front Bumper Pushbar $50.00
Shifter $10.00
Skid Plate $20
Plastic
Front & rear Fenders $100 - $300.00
Radiator Plastic $35.00
Gas Tank Plastic $35.00
Seat w/ latch $40-$100.00
Fender brackets $15.00
Electrical
CDI Box $60.00
Wiring harness / Loom $30.00 - $60.00
Coil $30.00
Headlights $75.00
on/off switch $25.00
Key w/ plastic housing $35.00
Taillight $20.00
Misc
Rear brake setup $125.00
Bolt set $30.00
Rear Shock $75.00
Front shocks $70.00
Front tires & rims $100.00 varies
Rear tires and rims $100.00 varies
Handlebars & grips $10.00
Clutch lever / perch $10.00
Thumb Throttle assembly $25.00
Radiator & Reservoir $25.00
Radiator and lines - $20
Front brake lines $10.00
Front brake lever/rezzy $15.00
Motor Mounts $10.00
motor parts:
cylinders $300
crank $175
shift drum, rods, forks $25
gears/tranny $130
cases $150-$200
clutch cover $30
stator cover $ 10
stator & timing plate $80-$100
internal bolts $25
head $15-$35
flywheel $75-$100
not for sale:
