Minkia38
Everything posted by Minkia38
  1. Running Engine $1000.00 Rubber intake boots/Boost $30.00 Reeds and cages $25.00 Carbs and cable $100.00 Airbox (or air filter) $50.00 Kickstarter $50.00 Gas Tank $30.00 Pipes $35.00 stock - $300.00 chrome aftermarket Frame components J Frame $100.00 (title add $100), A-arm frame, $250 (title add $100), Steering stem $25.00 A-arms / J-arms with brakes, hubs, spindles, and tie rods $300.00 Swingarm $30.00 Axle $100.00 Bearing carrier $40.00 Footpegs $10.00 Nerf Bars / Metal Heel guards $40.00, add $40 for plastic heel guard pieces Rear Hubs $40.00 Rear Sprocket & Hub $15.00 Rear Brake disc & Hub $15.00 Dogbone $15.00 Rear Grab Bar $10.00 Front Bumper Pushbar $20.00 Shifter $10.00 Skid Plate $20 Plastic Front & rear Fenders $100 - $200.00 Radiator Plastic $35.00 Gas Tank Plastic $35.00 Seat w/ latch $30-$75.00 Fender brackets $15.00 Electrical CDI Box $60.00 Wiring harness / Loom $30.00 Coil $30.00 Headlights $75.00 on/off switch $25.00 Key w/ plastic housing $30.00 Taillight $20.00 Misc Rear brake setup $100.00 Bolt set $25.00 Rear Shock $75.00 Front shocks $70.00 Front tires & rims $100.00 varies Rear tires and rims $100.00 varies Handlebars & grips $10.00 Clutch lever / perch $10.00 Thumb Throttle assembly $25.00 Radiator & Reservoir $30.00 Radiator and lines - $20 Front brake lines $10.00 Front brake lever/rezzy $15.00 Motor Mounts $10.00 motor parts: cylinders $300 crank $170 shift drum, rods, forks $25 gears/tranny $130 cases $150-$200 clutch cover $30 stator cover $ 10 stator + timing plate $80-$100 internal bolts $25 head $20 flywheel $75-$90
  2. I have several frame up on my ebay store, including a 2003 with a title
  3. Thanks for the positive comments guys!
  4. Thanks for the positive comments guys!
  5. I have red silver black frames, maybe a blue one too
  6. rear disc brake hub - $15 front rezzy complete - $15 shipping $12.75 for both
  7. sorry, no white shrouds
  8. please send all picture requests to me at [email protected] Frames, a-arm style, I have silver and black. J-arm style I have silver and red what color shocks do you want? I have red, yellow, white.... please see my signature for all my items to purchase immediately
  9. i have many red ones, but not from a 2004 rAY
  10. $30 for the old style one $50 for the new style one
  11. shipping on a carrier is $12.75
  12. sorry, i dont have any 2005 or 2006 taillights I have stock reeds for $20 low bore cylinders: $300 with pistons, bolt on condition!
  13. any year you want 1987-2004 Ray
  14. Engine 1,000.00 Intake boots/Boost 20.00 Reeds and cages 20.00 Carbs and cable 110.00 Airbox (or air filter) 50.00 Kicker 50.00 Gas tank 25.00 Pipes OEM 25.00 Frame components Frame 300.00 Steering stem 20.00 A-arms / J-arms 300.00 Swingarm 25.00 Axle 100.00 Bearing carrier 50.00 Footpegs 10.00 Nerf Bars / Heel guards 40.00 Rear Hubs 45.00 Rear Sprocket & Hub 15.00 Rear Rotor disc & Hub 15.00 Dogbone 15.00 Rear Grab Bar 15.00 Front Bumper Pushbar 20.00 Shifter 10.00 Rear Skid Plate 20.00 Plastic Front & rear Fenders 100 - 300.00 Grill + Radiator Plastic 30.00 Gas Tank Wrap Plastic 30.00 Seat w/ latch 50.00 Fender brackets 10.00 Electrical CDI Box 50.00 Wiring harness / Loom 40.00 Coil 20.00 Headlights 70.00 on/off switch 25.00 Key w/ plastic housing 35.00 Taillight 20.00 Misc Rear brake setup 100.00 Bolt set 25.00 Rear Shock 80.00 Front shocks 80.00 Front tires & rims 100.00 Rear tires and rims 120.00 Handlebars & grips 10.00 Clutch lever / perch 10.00 Thumb Throttle lever 20.00 Radiator & Reservoir 35.00 Front brake lines 10.00 Front brake lever/rezzy 20.00 Motor Mounts 10.00
  15. http://stores.ebay.com/Motor-City-ATV?refid=store
  16. $75 each for flywheels shipping is $15 for as many as you want
  17. $165 shipped for a flywheel and a stator
  18. also, does anyone know if the 2 different style carriers will fit any year swingarm?
  19. sorry, i dont have any white grills
  20. Alright, we have a little help, anyone else?
  21. I'm still around, just too busy to play on HQ for hours like I used to back in the day!
  22. I am working on a complete Banshee parts list, of what will fit other ATVs, as well as what years have interchangable parts If you would like to help, please feel free to post here, and I will confirm, and update the master list in this original post Frame: J-arm: 1987-1990 A-arm: 1991-2006 CDI Box: 2GU-50/2GU-51: 1987-1994 3GG-00: 1995-1996 3GG-10: 1997-2006 Wiring harness: round style: 1987-? square style w/ clear CDI plug: ? square style with gray CDI plug: ? On/Off handlebar lightswitch: round style: 1987-1994 small square style: (with sharp corners) 1995-2001 large square style: (with rounded corners) 2002 - 2006 *each wiring harness style is also specific for headlights, on/off light switch, key switch, *coil will fit any year *taillight will fit any year Stator: round style - 1987-1994 square style - 1995-2006 Rims/Wheel: Rear 4/115 bolt pattern - 1987-1988 & 1991-2006 - Banshee, Warrior, Raptor, YFZ450 Rear 4/156 bolt pattern - 1989 - 1990 Front: 4/156 bolt pattern - 1987-2006 Banshee, Warrior, YFZ450, Raptor Rear Sprocket: 1987-1990 - 4 finger style hub 1991-2006 - 6 finger style hub * axle will fit any year * brake hub will fit any year
