Minkia38
Everything posted by Minkia38
  1. Tons of stuff, I have a bunch up on ebay too: http://stores.ebay.com/Motor-City-ATV?refid=store Ray's current ebay auctions Frame components J Frame $150.00 (titled add $100), A-arm frame, $225 (titled add $100), Steering stem $30.00 A-arms / J-arms with brakes, hubs, spindles, and tie rods $250.00 Swingarm $30.00 Axle $100.00 Bearing carrier $60.00 Footpegs $10.00 Nerf Bars / Metal Heel guards $50.00, add $75 for plastic heel guard pieces Rear Hubs $35.00 Rear Sprocket & Hub $15.00 Rear Brake disc & Hub $15.00 Dogbone $10.00 Rear Grab Bar $15.00 Front Bumper Pushbar $50.00 Shifter $10.00 Skid Plate $20 Running Engine $1000.00 Rubber intake boots/Boost $30.00 Reeds and cages $20.00 Carbs and cable $100.00 Airbox (or air filter) $50.00 - $100.00 Kickstarter $50.00 Gas Tank $25.00, $15 for one with bad fenders mounts Pipes $35.00 stock - $300.00 chrome aftermarket motor parts: cylinders $300 crank $150 shift drum, rods, forks $15 gears/tranny $100 cases $100-$200 clutch cover with impeller $40, full mirror polished: $125 plastic stator cover $ 15 stator & timing plate $80-$100 internal bolts $25 head $15-$35 flywheel $75-$100 Plastic Front & rear Fenders $100 - $300 Radiator Plastic $35 Gas Tank Plastic $35 Seat w/ latch $40-$100 Front Fender brackets $15 Electrical CDI Box $60.00 Wiring harness / Loom $30.00 - $50.00 Coil $20.00 Headlights $80.00 on/off switch $25.00 Key w/ plastic housing $35.00 Taillight $20.00 Misc Rear brake setup $100.00 Bolt set $25.00 Rear Shock $75.00 Front shocks $80.00 Front tires & rims $50 - 200.00 varies Rear tires and rims $50 – 200.00 varies Handlebars & grips $10.00, aftermarket with pad $20 Clutch lever / perch $10.00 - $20.00 Thumb Throttle assembly $25.00 Radiator & Reservoir & lines$25.00 Radiator only- $20 Front brake lines $10.00 Front brake lever/rezzy $15.00 Motor Mounts $10.00
  2. the cover may be gone, but Ill take those fullbore front fenders!
  3. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=360208819549&viewitem=&sspagename=STRK%3AMESE%3AIT
  4. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=370291978401&viewitem=&sspagename=STRK%3AMESE%3AIT
  5. Holeshot Rear MX on Beadlocks - $225 - pics http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=290367827466&viewitem=&sspagename=STRK%3AMESE%3AIT
  6. I am working on a complete Banshee parts list, of what will fit other ATVs, as well as what years have interchangable parts If you would like to help, please feel free to post here, and I will confirm, and update the master list in this original post Frame: J-arm: 1987-1990 A-arm: 1991-2006 CDI Box: 2GU-50/2GU-51: 1987-1994 3GG-00: 1995-1996 3GG-10: 1997-2006 Wiring harness: round style: 1987-1994 square style with gray CDI plug: 1995-1996 square style w/ clear CDI plug: 1997-2006 On/Off handlebar lightswitch: round style: 1987-1994 small square style: (with sharp corners) 1995-2001 large square style: (with rounded corners) 2002 - 2006 *each wiring harness style is also specific for headlights, on/off light switch, key switch, *coil will fit any year *taillight will fit any year Stator: round style - 1987-1994 square style - 1995-2006 Rims/Wheel: Rear 4/115 bolt pattern - 1987-1988 & 1991-2006 - Banshee, Warrior, Raptor, YFZ450 Rear 4/156 bolt pattern - 1989 - 1990 Front: 4/156 bolt pattern - 1987-2006 Banshee, Warrior, YFZ450, Raptor Rear Sprocket: 1987-1990 - 4 finger style hub 1991-2006 - 6 finger style hub
  7. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=290363899175&ssPageName=STRK:MESE:IT
  8. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=290363019475&ssPageName=STRK:MESE:IT
  9. Frame components J Frame $750.00 (titled add $100), A-arm frame, $225 (titled add $100), Steering stem $30.00 A-arms / J-arms with brakes, hubs, spindles, and tie rods $300.00 Swingarm $40.00 Axle $100.00 Bearing carrier $60.00 Footpegs $10.00 Nerf Bars / Metal Heel guards $60.00, add $50 for plastic heel guard pieces Rear Hubs $40.00 Rear Sprocket & Hub $15.00 Rear Brake disc & Hub $15.00 Dogbone $10.00 Rear Grab Bar $20.00 Front Bumper Pushbar $50.00 Shifter $10.00 Skid Plate $20 Running Engine $1000.00 Rubber intake boots/Boost $30.00 Reeds and cages $20.00 Carbs and cable $100.00 Airbox (or air filter) $50.00 - $80.00 Kickstarter $50.00 Gas Tank $30.00, $15 for one with bad fenders mounts Pipes $35.00 stock - $300.00 chrome aftermarket motor parts: cylinders $300 crank $175 shift drum, rods, forks $25 gears/tranny $130 cases $150-$200 clutch cover $30 stator cover $ 15 stator & timing plate $80-$100 internal bolts $25 head $15-$35 flywheel $75-$100 Plastic Front & rear Fenders $100 - $300 Radiator Plastic $35 Gas Tank Plastic $35 Seat w/ latch $40-$100 Fender brackets $15 Electrical CDI Box $60.00 Wiring harness / Loom $30.00 - $60.00 Coil $30.00 Headlights $80.00 on/off switch $25.00 Key w/ plastic housing $35.00 Taillight $20.00 Misc Rear brake setup $110.00 Bolt set $20.00 Rear Shock $75.00 Front shocks $90.00 Front tires & rims $100.00 varies Rear tires and rims $100.00 varies Handlebars & grips $10.00, aftermarket $20 Clutch lever / perch $10.00 - $20.00 Thumb Throttle assembly $30.00 Radiator & Reservoir & lines$25.00 Radiator only- $20 Front brake lines $10.00 Front brake lever/rezzy $15.00 Motor Mounts $10.00 or check out my auctions: http://stores.ebay.com/Motor-City-ATV?refid=store
  10. http://stores.ebay.com/Motor-City-ATV?refid=store tons of banshee parts
  11. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=370278782741&ssPageName=STRK:MESE:IT what the title says, orange banshee fenders for $300 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=370278782741&ssPageName=STRK:MESE:IT
  12. no sorry, i dont have clamp on filters
  13. i have some with 60% tread left on aluminum rims for $140 plus $40 shipping
  14. blue rad cover and grill $ $40 2 plastic heel guards - $75
  15. it is a pro design, but it will work with a ricky stator one $55 total paypal: [email protected]
  16. i have a brand new in package pro design one for $50 plus $5.00 shipping Ray
  17. they sold on ebay this weekend sorry, I will try to get some more Ray
  18. i can take a money order from the post office email me for info: [email protected]
  19. stem $25 plus $15 ship bars - $5 stock, $20 aftermarket alum, $12 ship
  20. i have a shitty crank, shitty tranny, and shitty cases for $250 shipped
  21. if they dont sell on ebay, I usually drop the price by $5-$10 and relist them again
  22. yes, I have a set up on ebay right now for $150 click on my auctions link
  23. Yes, I do have an AC front bumper: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=360185665912&ssPageName=STRK:MESE:IT
  24. to ship a frame to PA = $150 plus $6.00 insurance to your local greyhound bus station.
