Minkia38
Everything posted by Minkia38
  1. yup, what he said, they will fit fine
  2. yeah, its getting parted out soon, but I thought Id try to figure out what was wrong with it instead of trashing the tranny...
  3. click on the signature, tons of banshee stuff for sale!
  4. looking for a banshee in SE michigan for $1500 or so
  5. sorry, those were sold back in May
  6. any help here guys? I bought a banshee, and it will not shift into neutral under any circumstance while not running, UNLESS I put it up on a stand and lift the rear tires off the ground.... thanks! Ray
  7. stock 2002 aluminum rims + dunlop kt877 80% tread - $100 rears, same thing, 75% - $110 shipping is $30 a pair
  8. stock stator please specify old round plug, or newer square style $75 plus $12.75 shipping paypal: [email protected] include a note saying what it is for! Ray @ Motor City aTV
  9. I have a j-arm frame with no title for $100
  10. Looking to purchase a few Banshees. Must send me pics: CLICK HERE TO EMAIL ME Must be in SE Michigan, or willing to deliver there A title is a plus aftermarket items are a plus Cannot spend over $2000, unless the suspension is all aftermarket
  11. yes taillight - $20 headlights - white - $50, black, $60 with grills
  12. sorry "parting out 15 stock Banshees - Michigan, will ship"
  13. $150 to ship the frame, frame prices depends on what you want, a or j arm, title or untitled...
  14. sorry, no saftermarket tators
  15. no pingles or paddles, those sell out real fast i have red tank plastic and grills check out my signature for auctions
  16. ive got a set up on ebay right now, not prerfect, but alot cheaper than new check out the link in my signature
  17. bump - up to 250 auctions now
  18. newest frame is around a 2001 or so Located in Northern Macomb, 48042 Engine1,000.00 Intake boots/Boost25.00 Reeds and cages25.00 Carbs and cable110.00 Airbox (or air filter)40-70.00 Kicker50.00 Gas tank$30.00 Pipes oem25.00 Frame components Frame300.00 Steering stem25.00 A-arms / J-arms300.00 Swingarm30.00 Axle100.00 Bearing carrier50.00 Footpegs10.00 Nerf Bars / Heel guards40.00 Rear Hubs45.00 Rear Sprocket & Hub25.00 Rear Rotor disc & Hub25.00 Dogbone10.00 Rear Grab Bar15.00 Front Bumper Pushbar20.00 Shifter10.00 Skid Plate20.00 Plastic Front & rear Fenders200.00 Grill + Radiator Plastic30.00 Gas Tank Wrap Plastic30.00 Seat w/ latch50.00 Fender brackets10.00 Electrical CDI Box50.00 Wiring harness / Loom35.00 Coil20.00 Headlights60.00 on/off switch25.00 Key w/ plastic housing35.00 Taillight25.00 Misc Rear brake setup100.00 Bolt set25.00 Rear Shock80.00 Front shocks80.00 Front tires & rims100.00 Rear tires and rims120.00 Handlebars & grips10.00 Clutch lever / perch10.00 Thumb Throttle lever30.00 Radiator & Reservoir30.00 Front brake lines10.00 Front brake lever/rezzy25.00 Motor Mounts20.00 cylinders 300 crank 150 shift drum 10 gears/tranny 150 cases 200 clutch cover 30 stator cover 15 stator + plate 75 bolts 20 head 25 flywheel 75
  19. Located in Northern Macomb, 48042 Engine1,000.00 Intake boots/Boost25.00 Reeds and cages25.00 Carbs and cable110.00 Airbox (or air filter)40-70.00 Kicker50.00 Gas tank$30.00 Pipes oem25.00 Frame components Frame300.00 Steering stem25.00 A-arms / J-arms300.00 Swingarm30.00 Axle100.00 Bearing carrier50.00 Footpegs10.00 Nerf Bars / Heel guards40.00 Rear Hubs45.00 Rear Sprocket & Hub25.00 Rear Rotor disc & Hub25.00 Dogbone10.00 Rear Grab Bar15.00 Front Bumper Pushbar20.00 Shifter10.00 Skid Plate20.00 Plastic Front & rear Fenders200.00 Grill + Radiator Plastic30.00 Gas Tank Wrap Plastic30.00 Seat w/ latch50.00 Fender brackets10.00 Electrical CDI Box50.00 Wiring harness / Loom35.00 Coil20.00 Headlights60.00 on/off switch25.00 Key w/ plastic housing35.00 Taillight25.00 Misc Rear brake setup100.00 Bolt set25.00 Rear Shock80.00 Front shocks80.00 Front tires & rims100.00 Rear tires and rims120.00 Handlebars & grips10.00 Clutch lever / perch10.00 Thumb Throttle lever30.00 Radiator & Reservoir30.00 Front brake lines10.00 Front brake lever/rezzy25.00 Motor Mounts20.00 cylinders 300 crank 150 shift drum 10 gears/tranny 150 cases 200 clutch cover 30 stator cover 15 stator + plate 75 bolts 20 head 25 flywheel 75
  20. Located in Northern Macomb, 48042 Engine1,000.00 Intake boots/Boost25.00 Reeds and cages25.00 Carbs and cable110.00 Airbox (or air filter)40-70.00 Kicker50.00 Gas tank$30.00 Pipes oem25.00 Frame components Frame300.00 Steering stem25.00 A-arms / J-arms300.00 Swingarm30.00 Axle100.00 Bearing carrier50.00 Footpegs10.00 Nerf Bars / Heel guards40.00 Rear Hubs45.00 Rear Sprocket & Hub25.00 Rear Rotor disc & Hub25.00 Dogbone10.00 Rear Grab Bar15.00 Front Bumper Pushbar20.00 Shifter10.00 Skid Plate20.00 Plastic Front & rear Fenders200.00 Grill + Radiator Plastic30.00 Gas Tank Wrap Plastic30.00 Seat w/ latch50.00 Fender brackets10.00 Electrical CDI Box50.00 Wiring harness / Loom35.00 Coil20.00 Headlights60.00 on/off switch25.00 Key w/ plastic housing35.00 Taillight25.00 Misc Rear brake setup100.00 Bolt set25.00 Rear Shock80.00 Front shocks80.00 Front tires & rims100.00 Rear tires and rims120.00 Handlebars & grips10.00 Clutch lever / perch10.00 Thumb Throttle lever30.00 Radiator & Reservoir30.00 Front brake lines10.00 Front brake lever/rezzy25.00 Motor Mounts20.00 cylinders 300 crank 150 shift drum 10 gears/tranny 150 cases 200 clutch cover 30 stator cover 15 stator + plate 75 bolts 20 head 25 flywheel 75
  21. Located in Northern Macomb, 48042 Engine1,000.00 Intake boots/Boost25.00 Reeds and cages25.00 Carbs and cable110.00 Airbox (or air filter)40-70.00 Kicker50.00 Gas tank$30.00 Pipes oem25.00 Frame components Frame300.00 Steering stem25.00 A-arms / J-arms300.00 Swingarm30.00 Axle100.00 Bearing carrier50.00 Footpegs10.00 Nerf Bars / Heel guards40.00 Rear Hubs45.00 Rear Sprocket & Hub25.00 Rear Rotor disc & Hub25.00 Dogbone10.00 Rear Grab Bar15.00 Front Bumper Pushbar20.00 Shifter10.00 Skid Plate20.00 Plastic Front & rear Fenders200.00 Grill + Radiator Plastic30.00 Gas Tank Wrap Plastic30.00 Seat w/ latch50.00 Fender brackets10.00 Electrical CDI Box50.00 Wiring harness / Loom35.00 Coil20.00 Headlights60.00 on/off switch25.00 Key w/ plastic housing35.00 Taillight25.00 Misc Rear brake setup100.00 Bolt set25.00 Rear Shock80.00 Front shocks80.00 Front tires & rims100.00 Rear tires and rims120.00 Handlebars & grips10.00 Clutch lever / perch10.00 Thumb Throttle lever30.00 Radiator & Reservoir30.00 Front brake lines10.00 Front brake lever/rezzy25.00 Motor Mounts20.00 cylinders 300 crank 150 shift drum 10 gears/tranny 150 cases 200 clutch cover 30 stator cover 15 stator + plate 75 bolts 20 head 25 flywheel 75
  22. everyhing went great as planned! highly recommended
  23. $85 for a strait axle $20 shipping
  24. Those sold on ebay a few days ago Ray
  25. I have a full set of black front and rear fenders for $280 I have a few pipes up on ebay, please see my auctions in my signature for the pipes
