remi_357
Everything posted by remi_357
  1. 32:1 here
  2. anyone have a extra? stock carbs no tors
  3. I run atf type f
  4. The back of the bottle on the 927 says it seperates at low temps. That why I switched to r-50
  5. i use atf type f. I buy the cheapest walmart has and change it often
  6. I run r-50. But I'm switching to super techniplate cause it is easier to get locally
  7. i think its a fair deal, but always try to talk them down
  8. those look sweet, might add that to my list
  9. agreed i would never put a twist throttle on a atv, but hey to each his own
  10. im just as cheap as the next guy, but if i was you i would get new filters
  11. These bikes look so much better with cut fenders. Great job
  12. looks good i like it
  13. craigslist is always good for a laugh
  14. looks good, im curious how those skis do i the snow......
  15. also i figured it was a bad idea to be cheap on the gasket. Figured I had to wait on the block off to get here, so i ordered a gasket the same day
  16. i just bought the quad so i have no idea what in it now. I went ahead and bought the $8 block off from ebay and im going to switch it to atf type f. thanks for the help everyone
  17. looking for the following billet stator cover billet clutch cover insert billet water pump cover billet impeller billet dipstick thanks
  18. Bench mounted buffer I take it?
  19. probaly a dumb question but I read that I have to remove the clutch cover to fix this, can I just use rtv black gasket maker for a new gasket?
  20. care to share the steps you took? maybe post a picture of the equipment you used? thanks
  21. hello everyone, my 2000 banshee has started leaking oil out of the clutch vent. It is not leaking out of the tube, however it is leaking between the nipple and the engine case. Is there a bad o ring? Im new to banshee's and have never taken one out. Would a block off plate be the best solution for fixing this? thanks
  22. Looking to add some color to my banshee. It is used mostly for trails. What's the better of the two? Paint or powder? I'm already set up to paint and would have to buy the gun and oven to powder coat and would still be limited to small parts only. You think painted frame swingarm and a-arms would hold up? Opinions?
  23. Pics to remi357@hotmail dot com thanks
