compose2
Everything posted by compose2
  1. i run all yamalube fluids in my shee. i tried shaking it and it made no difference. the strange thing is that it runs great once it started. plus if i shut it down while its warm, it will start on one kick
  2. been through all that. i tried switching the float bowl, made it worse. i made sure the crossover tube is connected. i just rebuilt the motor. 140lbs per cylinder. im clueless unless my choke is bad. is that possible? the motor should rev when i pull the choke but it bogs and stalls instead
  3. banchetta is right. reverse the plug wires and if the right side cylinder doesn't fire instead of the left, then is an electrical prob. if the left one doesn't fire like before, then its not electrical and should check air/fuel delivery
  4. i know i still have the stock pilots, but it maintains great idle and doesn't bog or anything when i rap on the throttle. i had dealership tell me that seldom do you need to change the pilot jet. how can i inspect the choke? is there anything i can see that would tell me its bad?
  5. i had k&n pod filters. man they were junk. they didn't filter crap. i switched to a team yamaha gyt-r 2 stage filter. 2 layer filter, inside was a fine foam, outside layer is a coarse brillow like filter. works excellent and allows better flow compared to stock filter
  6. my previous post stated that my shee would cold start only if i used starter fluid. i checked everything and its still the same prob. i recently trying pulling the choke out 1/2 when it was idling and warm, but it stalled right away. i thought that the rpm's show rise. gimme some feed back, tell me what you think it could be
  7. check your air filters. my shee had air filters on it that weren't feeding enough air to the carbs. made it run on one cylinder until i was at open throttle. find somewhere clean and dry to test and run your shee without an air filter. see if that helps. if it fixes the prob, just by new filters. by the way, what kind of filter are you running?
  8. does anyone know how many psi the rear shock should be filled to with nitrogen. i have nitrogen tanks at work and can recharge it myself for a stiffer shock.
  9. i'll try that. thanks
  10. should i try switching the carb bowls to see if it starts?
  11. im sure everything is back together good cuz once it started, i rode it a little and it ran great. tons of power. im just wondering why it is so hard to start initially.
  12. great spark in both cylinders. once i used the started fluid, it started in one kick. i think its not getting enough fuel to start it but once its running its fine
  13. my 99 shee will not kick start for the life of it. i ran a compression check and it was a little low so i put a new top end in with wiseco pro-lites. my compression is around 140lbs per cylinder now, still won't kick start. i sprayed starter fluid in the airbox and it started right away. maybe something with fuel delivery. please help!
