PolyKarbon
Everything posted by PolyKarbon
  1. One time I had this problem, come to find out the trottle cable housing broke at the spot where it branches off into two lines at the carbs. Only one carb would open. Check to MAKE SURE that BOTH carbs are opening. Hope this helps.
  2. JESUS CHRIST I JUST SHIT MYSELF!
  3. I've been on this Noss Head shit FOREVER and I know you're probably all really sick of my post on this subject, but...Before I had the head, I couldn't idle in first gear with my thumb off the throttle, it would just die if you didnt gas it. Now with the head on, I can putt around in first like it was a four stroke or something. Is this bad or is it just what the noss head does? I seem to have a lot more bottom end now. PS- DLNOSS, if my crank goes kaboom, I blame you!
  4. The same geometry. HAHAHAHA! Yeah, I really don't want a grenaded crank. I thought the head gasket might go first.
  5. If youre running 175 in compression, is that too much? What is too much, and what would be the first thing to break with too much compression?
  6. First off, I know there are 3 chain rollers. One on the swing arm, one above it, and one below it. Well, the roller on the swing arm is stuck, and I dont know how to route the chain through the other rollers. I believe the chain goes above the lowest roller, above the swing arm roller, and below the topmost roller correct? Ok, so whats wrong with my swing arm roller? Its stuck. And how do I loosen my chain, and how loose should it be? Thanks in advance.
  7. I cleaned my friction plates and rings with brake cleaner spray before, and let em sit in it for a while and put them back in. Clutch still works fine. Although, I will never do such a stupid thing again.
  8. AIR BOX CLEANING?! NEW PLUGS AND FLUIDS?!?!? ARE YOU KIDDING ME?! HAHAAHAHAHAH! I had a guy bore out both jugs for like 65 bucks all together. Thats the only thing you should have done. Everything else is too freakin easy and takes literally one hour at most.
  9. Couple of questions... 1. I bought spark plugs labeled BR8ES. I think these are the wrong ones because I have older ones labeled BP8ES and B8ES and so on.... So once and for all, what plugs do I need for running a Noss Head, 19cc domes, FMF pipes, at 540 ft above sea level? 2. I just got the shee together, and wanted to test it to make sure it starts. I didnt have any oil or coolant in it, so I just wanted to start it for 1/2 a second. Well, it started right up and so I tried to cut it off but I guess the on/off swith is broke. Whats going on here? 3. So, running a Noss Head at 540ft with FMF pipes and Boyeson reeds, I was told I should run high octane. I also heard the best solution is to add octane booster to get the octane up to 111. Is this true? With this screw up the engine or anything? Please help, and thanks in advance.
  10. The Mars Volta is music written by god handed down to man. They are the greatest band ever. I have like 3 copies of the cd, one for my car, one for my garage, and one for my house.
  11. Shambalamba Shit Flingers.
  12. My guy put nylon type screws in every hole before he coated it and they just popped out when h was done. The entire frame has to be stripped down because they heat it up really really hot. Also, tell him to mask off the steering stem bearing area really well and the foot brake pedal stem also. Those are two places I didnt have masked off and it was a bitch to sand off the powder coat. Get a clymers manual to help you put it all back together. Label all your connections on your wireing harness and al your coolant hoses and youll be fine.
  13. What they said. Noss for heads, ModQuad for bling.
  14. Whats up yall, I was in the field for a month but Im back now and guess what, MY WIFES PREGNANT! Im so excited! See yall later!
  15. Hey, this is polykarbon's wife. I need some help... Hes gone for a month and I want to get him some new plastics for his four wheeler while hes away ( Sort of a late Valentines day gift) What website is best to look for plastics? Thanks- The woman behind the man
  16. I couldnt own a car with a paint job like that. Id be too afraid to drive it.
  17. I wish you all would just shut the huck up you motherhuckers! Huck you all! Freestyler, do a hucking 540-McTwist-with-cheese-double-barrel-roll-can-can-with-a-kickstart-no-footer!
  18. You should have got the Traxxas Revo. CLICKY I think I want one!
  19. If you ever run your own buisiness and want to be succesful, act like dlnoss. He's tha shizzle for rizzle. Word.
  20. HQ for life here.
  21. Really? One time I was riding a trail through tall grass and a rabbit poped out in front of me and my wheels were like an inch from it. I kept trying to move out the way but I chased it down forever until it finally darted off the trails. Man, rabbits must be huge pussys if they die that easy. If I was a rabbit I would jump out of corners and scare my friends. Me: BOO! Friend: AHHHH! Me: Haha man that was good....you ok? Friend: ...
  22. I hate to bump this thread, but is Yamaha going to actually add the flux capacitor? If they do, then holy shit! Oh and Banshee Freestyler, the link is HERE.
  23. Hey man, just dont say "huck" anymore. That word makes my fuckin hair hurt. If you try a backflip, just say hello to the ground cuz that shits gonna be all over you like a tsunami on Thailand. PS- Sorry for the recurring Tsunami joke, but I made it up a while ago and find it rediculously funny to just let go after one use. I like to recycle my jokes. If you would like to use this joke, please fill out the co-signing form and send $5.00. Thank you.
  24. I thought it kicked ass. I play drums and was pretty impressed actually. I dont think they sound like the hives though.
