On the 2006 Banshee in my sig, carbs are sync'd, both sides getting fuel, both sides running in neutral but when the motor is under a load, the right side only fires intermittently up to 1/4 throttle, then it kicks in and and screams. I swapped plug wires, no change. I've tried 52 pilots and 48 pilots, no change. I half ass cleaned out the carb through the opening on the bottom of the bowl. (I couldn't get the bowl off at that time.) No change. I've now got the carb clean as can be.
I'm not sure what the float height should be. When I turn the carb upside down, the float rests all the way down in the carb, regardless of how it is bent. Is that normal? Is the float valve supposed to hold the float up? Gravity just pushes the float valve all the way in. Now I've messed with the bend and don't want to put it back together until I get some opinions.
Thanks
