canadabanshee
Everything posted by canadabanshee
  1. What is it,where is it, what does it do. Can I take it off. Does it make a big difference with or without it
  2. I got those to. I used one gromit on each side. Same with the washers one on each side. It took me a little time too to figure it out
  3. thanks man. Ohh its a new banshee. Just got it and the pipes were the first thing to go on.
  4. My banshee will not start it is not getting the right amount of gas i think. But if I put a small amount into the cylnders then put the spark plugs on it starts. And runs great. I just put on pro curicuit pipes and 220 jets. I put a few holes in the air lid. What esle should i do guys. And new spark plugs. When the engine is warm she starts up great.
  5. thats guys it was the tie rod end. It is perfert
  6. I got a 2003 banshee. I put pro curcuit pipes on it. 220 jets. I run high octang gold. I live in ontario canada. Like 100 above sea level or something. I put some holes in the air lide not to many. How many should I put. Is there anything esle to do to my banshee. Just card things. Or settings I should do.
  7. I think i got a carb problem. I just changed the jets. Its running great everything is good. But I put both carb caps on and tighten them down to 2.5ft each. But the top of the carb where u adjust the Idle speed they move a little bit. I am not to sure if they did before. Everything is tight. when you rev it up you can see them move. But everything is doing good she runs great
  8. When I turn right the left tire would hit the a arm. Sometimes stick. And in a turn it would turn me right around. The steering stoppers are still on. When I set the bashee in the air on its back with the front end up. And then turn the steering to the left the tire just goes to the left and hits the a arm. Looks like the ball joints and tie rod ends are good. Dunno whats wrong and how to fix it
  9. Yea man. That was the first thing I did. They are both there. And my tie rods are both good not bent or anything. It just happened I got to get it up and check it out
  10. Hey. I was riding today. I hit a rock going slow. And my left tire went all the way to the left and hit the a arm. Its got play but dunno from where. So when I turn now sometimes the left tire jams into the a arm on a left turn. need help guys
  11. Does anyone here have Tag bars. The CR type. If so how do you like them
  12. I got pro circuit pipes. Great pipe. But my pants melt on them. How do I clean the pipes
  13. I went to that web site. But I think its the wrong one man
  14. canadabanshee
    Nos
    I got nos in my old car. I want it in my banshee. Speed is fun. And for the money its worth it to me. What set up is the best.
  15. Yea.. I ride all over. Some sand.. Lots of dirt.. Mud.. water
  16. I got A 2004 Banshee. I put pro cuirut pipes on it. With 220 jetting. I am from ontario. Umm I want a air filter set up. I am thinking dual k and n. Would that be good or to much. And then change the jeeting
  17. Can I stock Banshee run on Alcohol. Well if you got pipes,air filter,jetting.
  18. Can I stock engine in a banshee run off of Alcohol
  19. Plugging it did not work. It still leaks. Its a vertical rip in the tire. So when you bounce on it or ride it opens up. I might try to patch it
  20. Yea I just plugged it. It took five of those rubber things. Never ever did try to use them in the side wall before. Only on the thread part of the tire. I shall see what happens
  21. I got a flat tire on my banshee. But dont want to buy a new one. Cause its a studded tire for ice racing. The hole is in the side wall. How should I fix it or should I just put a tude in it if the studs dont go right though it .
  22. Is it worth it. What does it do. Bottle boost. Here In canada I can get it for 60 new I think. Where does it go to
  23. Hey. I just put on New pipes. Pro curict pipes. Should I do anything to the air box cover to help it get air. What else should I do
  24. What do you guys think about the pro curcuit pipes. The low end power and top end. How does it compare to other pipes in that price range.
  25. Has anyone ever done ice racing. I plan to just waiting for ice. I have over 1000 suds in the tires. I think its going to be a blast. I am looking for tips and tricks if anyone has ever done this before thanks
