03limitededition
    03 limited, gnarly pipes, powercore 2, cut head, tdr reeds, reed spacers, boost bottle, 3 degree key
03limitededition's Achievements
  1. Just wanted to post to thank and praise Boonman for the great job and quick turnaround on my Flywheel. The difference in throttle response is significant. Thanks!!
  2. They send the money to your e-mail address, when you set up your paypal account, you entered your e-mail address.
  3. Did anyone (besides me) want to reach though the f#$@ing television and choke the S%$T out of them?
  4. loganskinner, love the avitar
  5. What I think is interesting is how the general public puts motorcycle/Atv accidents under a microscope when stupidity runs rampant in all forms of recreation. What about the jackass who dives in a shallow pool or golfs in an electrical storm, or........ well, you get the idea.
  6. I just took my stator cover off to send my flywheel to Boonman. When I took it off, the flywheel, stator, pickup, and stator plate all looked like s**t!!!! Water has been getting in there somehow. I checked the gasket and it looked fine. This quad is nearly new, why/how is water getting in there? and how should I clean the components? Has anyone else had this problem? Thanks for any thoughts or input.
  7. I have the gnarly pipes, pro circuit sparkarresstors, 3 degree key, Head shaved .020, proflow and K&N. I know I might get flamed for saying this, but with all the mods I listed above, I added a boost bottle, reed spacers, and TDR hypertension reeds. The combination of all these things together makes GREAT bottem end and midrange, very snappy throttle response and better than stock topend. I run the stock rear gearing and one tooth larger on the front. The taller gearing gives more range in each gear. In my opinion first and second gears are low enough. Also, I've read that a lightened flywheel helps alot. Hope this helps and good luck!!!
  8. I have stock carbs, I also have fmf pipes (gnarly), and I ordered mine from alba. They really cleaned up my midrange,( 1/4 to 3/4 throttle). Hope this helps!
  9. I think you could get about any silencer to work with a little fab work. almost all pipes and stingers route ABOUT the same way. many times the angle and stinger length are the only differences. I currently have fmf gnarly pipes with pro circuit spark aresstors. I had to heat and bend them slightly and add 2 inches to the length. they work great and don't touch anywhere. They actually fit better than the fmf silencers because I custom fit them. The other issue would be that the Paul Turner pipes are tuned to the fat boy silencers. So it may change the power delivery. Although, my setup runs virtually the same as it did with the fmf silencers, they just sound different. Hope this helps!
  10. An extemely lean condition can cause one or both cylinders to cut out, and seem like a fouled plug. also, check your float settings along with your jetting. I agree with the other replies, you should be at LEAST at a 280 main jet if you have stock carbs. Read the jetting faq, Take your time and try to enjoy the tuning process. I enjoy tweaking my shee almost as much as riding. Good luck! My 2 cents
  11. The gnarlies are great pipes IMO, They Increase bottom and mid power with AT LEAST stock like top end (I think maybe a little more on top, but I have other mods). I wouldn't worry about reed spacers, I would just upgrade the air filter setup, If you havent already, and run the gnarlies. I have the gnarlies, K&N, 3 degree advance key, 145psi head, TDR reeds, and I went up one tooth on the countershaft sprocket, Runs Fantastic. My .02
  12. Thanks for the offer, but I can't really use the geecko's and I kind of have my heart set on the T-9 Baja's. or beadlocks. The beadlocks would be worth more than the T-Maxx, so I'm looking for the baja's. I will drop the Buy it now price for any HQ member.
  13. Looking to sell this or maybe trade something, I would like a set of nice used T-9 Baja wheels. 10 inch front and 9 in rears. Maybe take partial trade on something else. Thanks http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...MESSE%3AIT&rd=1
  14. I have the gnarlys with pro circuit sparkarrestors. I like this setup alot, great low end and mid range with more on top than the 2into1. I had powercore2's before and lost no power when I installed the procircuits. although I had to weld 2 inches of pipe to the stingers to make them work. the procircuits have a nice bark (sound) to them.
  15. I was thinking maybe it was the castor or the synthetic/castor blend of the klotz, that maybe made the difference, I Don't know.
