Basicorpse
Everything posted by Basicorpse
  1. I just installed my cascade shift star today everything went smoothly however I have a question. All the teeth on the star are ground down but one. One of the teeth have not been touched and is the same length as a stock tooth. Is this normal?
  2. Toomey has clutch springs on thier site. The springs are 100% stiffer than stock though so you may want to use half stock springs and half thier springs.
  3. Maybe you arent getting a good spark and when you hit the gas it floods the engine because its not able to burn it all?
  4. No problem. Mine leak slightly from the overflow tubes while the bike is sitting so I just turn the petcock to the off position when I store it. I don't think there is any fix for that. My buddy has an 04 banshee with 20 hours on it and his does it as well.
  5. Your float inside your carb is probaly stuck. Try tapping that carb lightly with a screwdriver and see if that helps.
  6. How do you like your barnett clutch? My buddy told me that I should be able to put more power to the wheels now due to the clutch slipping less. I'll probaly end up doing half stock springs and half of the barnett springs. I dont really have enough mods to justify having an insanely stiff clutch.
  7. Yea I ended up orderin one off fleabay as well. Does anyone know how much stiffer the barnett clutch springs are than stock? Should I use all 6 barnett springs or use 3 barnett and 3 stock?
  8. Haha yea I guess you are right I mean I just dropped about $250 on mods and parts no sense in seizing them up for a measly $4 of oil.
  9. See sig sorry if its tough to see took the pic with my camera phone. I'll try to get some better pics for you.
  10. Thanks thats exactly what I was looking for. The oil I drained only had one ride on it so I think I'll reuse that oil and then change it after I wear in the clutch.
  11. I just ordered a prodesgin impeller, barnett clutch kit and cascade shift star. My bike should be a whole different machine when I get it all back together can't wait. Any tips for installing the new clutch?
  12. You're right splitting the case was not the correct term. I meant what mods can I do while I have the right side case apart. Where can I get the shift star mod?
  13. Yea I just sold my paintball gun for $500 so I'm pretty much going to dump all that into my shee. I was thinking about gettin the ebc clutch kit with the 10% stiffer than stock springs. My clutch looked fine but I figure I might as well upgrade now that I have pipes and tires.
  14. I have my case split to replace my shifter shaft. I replaced the shifter seal and it still leaked oil from the shifter so I assume that the shaft is worn. I was thinking about doing a clutch and impeller. What brands do you guys recommend? Will just getting stiffer clutch springs make a difference?
  15. How hard is it to replace the shift shaft? That is where it is leaking from the inside portion of the seal where it goes around the shifter shaft.
  16. I have a problem with my 01 banshee. When I first got it, it was leaking from the shifter seal so I replaced it and everything was fine. Now today about 6 months later it started leaking from the shifter seal again. So today I went and replaced the seal thinking that was the problem. Unfortunately it still leaks from the shifter seal. What could be wrong? I noticed the leak yesterday after a long day of hard riding. I am using belrays gearsaver transmission fluid.
  17. Thanks alot guys for all the suggestions. I will take a look at it tommorrow and report back.
  18. Yea thats what I intially thought but I wasnt sure. How hard are they to replace?
  19. On my 2001 banshee if I grab the top of the wheel I am able to move it back and forth slightly. The hub is nice and tight and so are the wheel nuts. I think I may be some kind of bushing but Im not sure what to replace.
  20. Im located in Worcester and am always looking for new locations to ride. I'd definetly be interested in riding let me know when and where.
  21. Please forgive my newbie question but what is the correct way to mount the front rims? Right now the deep part of the rim is facing inward and the shallow part is facing outwards. I believe that the correct way to mount them is the reverse direction but my valve stems hit my caliper mounted the other way.
  22. One more thing to add. I just looked on ebay and I saw a blaster hub for $10 will this fit my bike? Also if the studs are replaceable where can I find them?
  23. One of the rear studs that holds the wheel to the hub stripped out on me today. My question is do I have to replace the entire hub or are the studs replaceable? How safe is it to ride on 3 out of 4 nuts holding the wheel to the hub?
  24. I agree cutting the rear fenders is ugly.
  25. I just took it apart because I had a slight bog off idle. The needle was in the 4th position down from the blunt end. It was an attempt to figure out why I already had 270 mains in there with stock pipes and filter. If my quad overheats easily is that a sign of a rich or lean condition?
