mskarl
    97 black, milled head, knn and pipes
mskarl's Achievements
  1. i am thinking you mean 5 thousanths I'm sure your right. I've never had a head milled so I don't know my brother took care of that.
  2. I understand that the new carbs have the TORS removal but did you unplug the parking bike sensor, and the throttle sensor? Also is the little black box under the left side (while sitting on it) under the frame unplugged? Look at the trouble I had on this topic and see if it applies to you. http://www.bansheehq.com/forums/index.php?act=ST&f=4&t=28249
  3. It had vtec (spell) pistons that were 1 over (I think) again my brother took care of that. And the head was milled 5mm from what I understand. And mistakenly we did not measure the rings before we put the bike together.
  4. My brother said to e-mail him with your information etc for the head at [email protected] We live in Tacoma WA. And I'm not sure what he wants to sell it for. I know he has put a fair amount of money into it. I'm the one with the garrage so we work on it at my place. Ohh how do you do a leak down test? Does anyone know???
  5. how much do want for the stock head?? I am interested so I put it together and sell it!!
  6. how much do you want for the stock head?? I want to put it back together and sell this damn money pit!!!!! Maybe better luck with another one... Thanks
  7. how much do you want for the head??? that would be cool to get then I want to see this damn thing due to all of the problems!!!
  8. I understand that part about why this piston looks like that buy why did it break?
  9. Here is a pic of the plugs I know it's hard to tell the color sorry.
  10. Is there anyway to save this head?
  11. After getting it running this is what happened. For specs etc look at this post. http://www.bansheehq.com/forums/index.php?act=ST&f=4&t=28249 Ok we started out with running really rich. 310 main and on middle clip on the needle. It's stock carbs with KNN's. Pulled the plugs and they were really wet and lost of oil. The only other jets we had were 290's and that's what we put in. Then after riding 1hr or so in sand it over heated on a cool day 55deg and raining. My brother was riding it and he said that he was about 1/2 throttle most of the time and then it died and it boiled over a little. He waited about 20 min and kicked it over. Seamed to have a little less compression. Got it running and rode it approx 1/4 mile and then he heard a ping sound and died. The engline was froze. When we pulled the spark plugs they weren't horrible. We pulled the heads off last night and found out that on the right piston the skirt broke. We pulled the piston off and felt the crank. Up and down is tight but side to side has about a 1/4in travel. Also something else that is confusing is that it's still really hard to kick over even with the head off but you can move the pistons. Is that maybe because the Clutch barring went south? If so can you check that without pulling off the side? Lots of questions!!!!!! Thanks in advance Questions. Is there anything we can do about the head? Or just get new? Why would the skirt break? becasue of the over heating? Is there too much play in the crank? Doesn't this side look good?
  12. OK well I feel stupid. They guy that said check the parking break was right. The switch was still plugged in and that was the trouble. Running fine now. Tanks for all the help!!!!!!!!!!!!!!1 now I can stop and have fun.
  13. We did not install a timming plate. Also we disconnected the T.O.R.S. control box, so that should rule out the parking brake right???? Still not working. Appreciate the help!!
