diggerzmound
Everything posted by diggerzmound
  1. I'm interested in the beadlocks. Do the tires hold air and will you ship them?
  2. Stator.. Stator, Stator ! did I mention it could be the stator? Get the service manual out and check specs, I'll almost guarantee your trigger coil is just barely out of specs. The warrior is notorious for this...
  3. I don't think a single setup would do your build any justice. My single runs good on my modified shee but mine definitely is not 60 HP.
  4. You can run 87 in your current build. Get some 19cc domes and mix that 110 half and half with 91 and you'll be good.
  5. As the topic says, I am looking for a cable for stock thumb to the 35mm carb that comes with the Trinity 2 into 1 kit.
  6. May be your plug boots. If that doesn't fix it, get your multimeter out and test your stator.
  7. I have more 2 strokes than 4 strokes, my most interesting rides are two strokes. I think there is a point where it ends up less expensive to keep up with the 'racer' crowd building a banshee. I've seen some cool stuff come out of the experimental garage, low budget hot running stuff. A stock bore raptor, stock piston, mystery cam ground specifically for this motor. Stock carbs, no main jets, running methanol and warrior shocks, killing OOF 8" swinger banshees. It was fun to see them ride by and stare at it. Didn't look good, but the right guy on it and it ran pretty good.
  8. How much did your intake and reed setup cost you??? You run 39's on stock reeds and intakes? I can tell I'll never make way in this conversation.. :sad:
  9. A stroker crank for either is nearly the same, 2 less expensive pistons = 1 expensive piston. I've got both a stroked 660 and a not stock banshee. The costs are the same to get them to push out the same power. A good pipe for my 660 is $300, the header not needing changed even for my stroker setup... T-5's are over $500... Good carb and intake setup on a banshee is $800 to keep up with the mods. My stock carbs worked good on my 720, the 39's are about $1000. Porting = same.... Where are you saving so much money building your 2 stroke.. Does dragonfly sell a stroker kit now?? There is nothing that can beat a banshee once you lay out your credit card... Those cub cylinders just don't run right without the right pieps, and intake. These arguments are funny for a short time.......
  10. PM'd you.
  11. Still thinking about it. Nice talking to ya.
  12. Title says it all, if you have a set of rear 4 X 156 hubs, give me your price and your email. Thanks!
  13. WHere are you at?
  14. I have a set of FMF Gold Series pipes with Don somebody's name on them. I would guess they are a low end pipe by the shape, the expansion chambers are fairly small diameter. The expansion chambers are in good shape, there is one shallow dent on the inside of one of them. The silencers are in fair shape, they have some dents but polish up nice. They are going to need repacked. I would like to get $200 shipped, or make me an offer trades or money.. No hardware... (dent) I also have a set of Duncan Silencers, they are in decent shape, one has had the stinger rewelded to the can, and both need repacked. The inlets are not in the best shape, exhaust clamps would resolve this though. I'd like $40 shipped. No Hardware.. PM me or email - [email protected] paypal or money order
  15. Pm sent
  16. Can you measure the OD of the part of the spark arrestors that slips inside the pipes for me? I am interested if they are the correct size. Thanks
  17. How Ratty and what you want for them? Thanks
  18. I am looking for any type of exhaust clamp for my FMF pipes. I also would like a set of Black nets for my DG Alloy Nerfs. Thanks!
  19. I'd like the Holeshots if you will ship them to Nebraska.
  20. http://www.yamahasportsplaza.com/pages/par...16/default.aspx $8.07 each.
  21. I am part of the 'nebraska crew' I would love to go, but it will have to be earlier June, or after the 4th of July. I sell and organize the fireworks sales and display in town. So the week prior and up to the 4th are very busy for me. Do not by any means plan your ride around what I have said. I am planning on making it to KP sometime this year though. If nothing else I'll shoot you a message and we can meet up then.
